DCM Belt surfacer
DCM Belt surfacer
I have a DCM belt resurfacing machine for sale. The coolant pump was removed and has been used dry. It works great. Located in the Minneapolis area. $1500
Re: DCM Belt surfacer
Do you know what it weighs? What are the power requirements?
“If I hit you with this you’re going to be numb, that’s why they call them numb-chucks “Si Robertson
It is 20hp three phase 220 volt. It was on a 100 amp breaker. I don't know the exact weight but I would guess 1200-1500 pounds.
