Alternative to BHJ
Alternative to BHJ
Getting ready to put Bed Mill in service. Need fixturing to locate 2in diameter bar for block work. So far have only heard and seen BHJ V block/hold down fixture. They also sell a fixture to hold the block @ correct angle for Deck/bore. Its 379.00 alone. Any Alt. suggestions. Could prob. make the Tilt fixture if I had a picture and some basic dimensions. Thanks Al
Some people are so stupid that they dont even know it! - by a famous Hillbilly
Re: Alternative to BHJ
There is already thread discussing DIY options:
viewtopic.php?f=32&t=41619
We bought a 4' stick of turned, ground, polished 2" for $108.
A shop I visited made their clamp setup from a pair of 6" Chicom V-blocks, some T-bolts to hold it to the stanchions and a pair of C-clamps which have a small V-block pad on the screw. They had less than $100 in it.
I had a machinist friend with a CNC lathe whip up seven different sets of main bore adapter rings for less than half what BHJ wanted.
If I were making the plate, I'd use thicker stock so standard Starrett levels would sit better.
