"Fossil fuel" reality check
Any topic with a chance of polarization - Not for the easily offended.
exhaustgases
Post by exhaustgases » Tue Oct 10, 2017 2:23 am
And remember this is one of 6 fuel spray nozzles in a not so big jet engine, and the video shows it not even running at full capacity.
And we wonder where the fuel is going? Or the emissions etc.
https://www.youtube.com/watch?v=5fRBOkXvAK0
GARY C
Re: "Fossil fuel" reality check
Post by GARY C » Tue Oct 10, 2017 2:38 am
How many barrels of oil do you get from a dinosaur and how did they all fall into one hole? :D
that vid reminds me of the topfuel, fuel pump demonstration that required a fire hose.
paulzig
Post by paulzig » Tue Oct 10, 2017 2:48 am
Bit of a misnomer as there are no fossils in 'fossil fuel'.. :)
GARY C
Post by GARY C » Tue Oct 10, 2017 3:00 am
Yeah, I think the largest fossil graveyard is over 500 acres and there isn't 1 qt of 10w30 to be found.
Post by pdq67 » Tue Oct 10, 2017 3:44 am
But there is a lot of tar at La Brea!
And it's filled with fossils.
paulzig
Post by paulzig » Tue Oct 10, 2017 4:11 am
The term fossil is misused here to refer to something that is old or aged... The fuel itself is decaying organisms under pressure and heat not fossils.
Dave Koehler
Post by Dave Koehler » Tue Oct 10, 2017 9:34 am
25gpm. Pretty efficient compared to a Top Fueler.
Where does the fuel go? Converted to thrust of course.
Did you expect to see a nozzle that injects the "special" chems on an engine from the 50s?
That fellow has some interesting videos. Much can be learned.
exhaustgases
Post by exhaustgases » Wed Oct 11, 2017 10:18 am
I used the fossil term since that's what every one "thinks" its called, cause its the pushed term. Mineral fuel and oil is the correct term.
50's or not, it is still the norm or even worse the bigger the engine you go in that world. When those engines run its like flushing fuel down the toilet every second. I just thought it was nice to get to see the amount of fuel used for one of six fuel nozzles that are flowing for a slow speed or thrust setting.
Post by pdq67 » Wed Oct 11, 2017 1:11 pm
A real world gas mileage reality check here using my old survivor '67SS/RS Camaro car.
Stock, 295hp/350, M-20 and 3.31 regs and about 25.3"/29.5" dia. or so tires was like 16.5 to 17 mpg running about 70 mph back then.
Same combination, but with a 350hp/327, -151 hy-cam in her! About 15.5 to 16 mpg! The old -151 cam pulled like a, "freight train"!!!
My old, junk301 with an old junkyard, -097 Duntov in it was still like 16 mpg. Sucker would hit 7,000+ rpm any time I put my foot in it!
I didn't keep the old hopped up 300hp/327 that was in my car when I got it back so don't know. It had a 268 hy-cam in it. Those damned little 268/270 hy-cams run fine in the old 250/275/300hp/327 engines! One will wake them right up!!
I never figured the gas mileage for my .060" over, 11.5 to 1 CR, full house/"tripped", 409 "W" engine, but I always thought it would be about 10 mpg??
The big sucker ran like a 283 on steroids!!
Now my Strong-Arm 406, about 15 with 26.5" dia. tires running about 55 mph on the 4-lane commuting daily. Cam was a 292/230, 109/107 or so, .480" lift old-school jobber!
I haven't lit off my 496 yet so don't know how it's gas mileage will be?
David Redszus
Post by David Redszus » Wed Oct 11, 2017 3:42 pm
This is a topic I looked into a few dozen years ago; horsepower vs fuel economy.
Given the same body shape (similar frontal area and Cd) and running at the same mph, fuel economy results were nearly equal.
So how much horsepower does it take to propel a Camaro at a constant 70 mph? How much fuel?
Post by pdq67 » Wed Oct 11, 2017 4:01 pm
David,
I came to about the same conclusion after I looked close!
It's not until you put your foot to the floor that gas mileage changes all that much.
Then we are going from Mpg to Hp!!!
exhaustgases
Post by exhaustgases » Wed Oct 11, 2017 6:45 pm
If it is fuel mileage the best fuel mileage would be from a large airliner with turbo compounded diesel engines on it, even the old gas engines beat the jets in the better fuel consumption area.
David Redszus
Post by David Redszus » Wed Oct 11, 2017 7:47 pm
David,
Assuming a frontal area of 28 sqft, with a Cd of 0.48, at a steady 70 mph, our car will require 35 hp.
GARY C
Post by GARY C » Wed Oct 11, 2017 8:05 pm
Any idea how it all ended up in one hole?
Any idea why many of the wells thought to be empty have refilled them selves?
paulzig
Post by paulzig » Thu Oct 12, 2017 4:57 am
Plate tectonics and the formation of basins causing the biomass to drop in there?
secondary reservoirs deep inside the earths crust under pressure, feeding into the primary reservoirs as the oil is depleted maybe?
