Anti Warming News
exhaustgases
Re: Anti Warming News
Post by exhaustgases » Sat Sep 16, 2017 10:10 pm
They will engineer the climate to change, you will have to believe and be assimilated into the borg. Or is it Gorb?
Post by Ken0069 » Sun Sep 17, 2017 5:54 pm
Former NASA GISS climate scientist tells new NASA head to stop funding “corrupt, carpet-baggers”
A new incendiary blog by Dr. Duane Thresher and Dr. Claudia Kubatzki unleashes on NASA Goddard Institute (one of the two main motherlodes of climate activism), calling for them to be defunded because they are “ignoble”, with “herds of do-gooders”, and “NASA GISS is a monument to bad science that truly should be torn down. Take the money and buy a rocket.”
They are a husband and wife team, both producing peer-reviewed climate papers. He worked at NASA GISS for seven years. Since they came out as skeptics in California, they’ve had to move house. Thanks to Marc Morano for the tip.
His latest post calls on the new NASA head, appointed by Trump, to just turn off the tap, cut the cash:
Bridenstine, Climate Scientists Are Not Noble, Stop Paying Them
Everyone assumes climate scientists are noble. Fighting to save the planet. What nonsense. Not even close.
They write about a wave of new money into climate science and the decay of the field:
Enter opportunists, carpetbaggers, the corrupt, the ignoble.
What to do? Stop paying climate scientists. The good ones are so into their science they will work for food, maybe less, maybe even pay to do it. French President Macron has invited the rest to move to France so they will be fine.
Start with defunding NASA GISS where this whole global warming nonsense started. It was started by James Hansen, formerly head of NASA GISS and considered the father of global warming. It was continued by Gavin Schmidt, current head of NASA GISS, anointed by Hansen, and leading climate change warrior scientist/spokesperson.
Thresher is an MIT graduate in electrical engineering, and went on to study Atmospheric Science (climate modeling), has done Antarctic research, got a PhD from Columbia and worked for James Hansen and Gavin Schmidt at NASA GISS. His wife Kubatzki, is a meteorologist, climate modeler, pollen proxy analyst and a a native German. She’s worked at the Potsdam Institute for Climate Impact Research (PIK), Germany.
Being a whistleblower is always risky:
If you think neo-Nazis are bad, try being a global warming skeptic in the Bay Area of California, where we had to move from for our own safety.
Gavin Schmidt “couldn’t make it” in maths so he became a climate scientist
Read the rest of this article HERE!
Post by Ken0069 » Thu Sep 21, 2017 3:49 pm
The 11-Year Major Hurricane Drought: Much More Unusual than Two Cat 4 Strikes
September 21st, 2017 by Roy W. Spencer, Ph. D.
http://www.drroyspencer.com/2017/09/the ... 4-strikes/
Weather.com published an article noting that the two Cat 4 hurricane strikes this year (Harvey and Irma) is a new record. Here’s a nice graphic they used showing both storms at landfall.
But the statistics of rare events (like hurricanes) are not very well behaved. Let’s look at this new record, and compared it to the 11+year period of no major hurricane strikes that ended when Harvey struck Texas.
The Probability of Two Cat 4 Strikes in One Year
By my count, we have had 24 Cat 4 or Cat 5 landfalls in the U.S. between 1851 and 2016. This gives a probability (prior to Harvey and Irma) of one Cat4+ strike every 7 years. It also leads to an average return period of two Cat4+ strikes of about 50 years (maybe one of you statiticians out there can correct me if I’m wrong).
So, since the average return period is once every 50 years, we were overdue for two Cat4+ strikes in the same year over the entire 166 period of record. (Again, for rare events, the statistics aren’t very well behaved.)
The Probability of the 11-Year “Drought” in Major Landfalling Hurricane
In 2015, a NASA study was published which calculated how unlikely the (then) 9-year stretch with no major hurricane landfalls was. They came up with a 177 year return period for such an event.
I used that statistic to estimate what eventually happened, which was 11 years with no major hurricane strikes.
I get a return period of 560 years!
Now, which seems more unusual and potentially due to climate change: something that should happen only once every 50 years, or every 560 years?
Maybe global warming causes fewer landfalling major hurricanes.
The List Rev A =;
David Redszus
Post by David Redszus » Tue Sep 26, 2017 9:29 pm
What's the hottest Earth's ever been?
Our planet probably experienced its hottest temperatures in its earliest days, when it was still colliding with other rocky debris (planetesimals) careening around the solar system. The heat of these collisions would have kept Earth molten, with top-of-the-atmosphere temperatures upward of 3,600° Fahrenheit.
Even after those first scorching millennia, however, the planet has sometimes been much warmer than it is now. One of the warmest times was during the geologic period known as the Neoproterozoic, between 600 and 800 million years ago. Another “warm age” is a period geologists call the Paleocene-Eocene Thermal Maximum, which occurred about 56 million years ago.
History of hot
Temperature records from thermometers and weather stations exist only for a tiny portion of our planet's 4.54-billion-year-long life. By studying indirect clues—the chemical and structural signatures of rocks, fossils, and crystals, ocean sediments, fossilized reefs, tree rings, and ice cores—however, scientists can infer past temperatures.
None of that helps with the very early Earth, however. During the time known as the Hadean (yes, because it was like Hades), Earth’s collisions with other large planetesimals in our young solar system—including a Mars-sized one whose impact with Earth is thought to have created the Moon—would have melted and vaporized most rock at the surface. Because no rocks on Earth have survived from so long ago, scientists have estimated early Earth conditions based on observations of the Moon and on astronomical models. Following the collision that spawned the Moon, the planet was estimated to have been around 2,300 Kelvin (3,680°F).
What the collision that spawned Earth's Moon may have looked like. Collisions between Earth and rocky debris in the early solar system would have kept the surface molten and surface temperatures blistering.
Even after collisions stopped, and the planet had tens of millions of years to cool, surface temperatures were likely more than 400° Fahrenheit. Zircon crystals from Australia, only about 150 million years younger than the Earth itself, hint that our planet may have cooled faster than scientists previously thought. Still, in its infancy, Earth would have experienced temperatures far higher than we humans could possibly survive.
But suppose we exclude the violent and scorching years when Earth first formed. When else has Earth’s surface sweltered?
Thawing the freezer
Between 600 and 800 million years ago—a period of time geologists call the Neoproterozoic—evidence suggests the Earth underwent an ice age so cold that ice sheets not only capped the polar latitudes, but may have extended all the way to sea level near the equator. Reflecting ever more sunlight back into space as they expanded, the ice sheets cooled the climate and reinforced their own growth. Obviously, the Earth didn’t remain stuck in the freezer, so how did the planet thaw?
Even while ice sheets covered more and more of Earth’s surface, tectonic plates continued to drift and collide, so volcanic activity also continued. Volcanoes emit the greenhouse gas carbon dioxide. In our current, ice-age-free world, the natural weathering of silicate rock by rainfall consumes carbon dioxide over geologic time scales. During the frigid conditions of the Neoproterozoic, rainfall became rare. With volcanoes churning out carbon dioxide and little or no rainfall to weather rocks and consume the greenhouse gas, temperatures climbed.
What evidence do scientists have that all this actually happened some 700 million years ago? Some of the best evidence is "cap carbonates" lying directly over Neoproterozoic-age glacial deposits. Cap carbonates—layers of calcium-rich rock such as limestone—only form in warm water.
Rock formation in Namibia that shows a type of rock that only forms in warm water (cap dolostone) lying directly over a type of jumbled sedimentary rock, dated to 635 million years ago, that is commonly found at the margin of glaciers (diamictite).
The fact that these thick, calcium-rich rock layers sat directly on top of rock deposits left behind by retreating glaciers indicate that temperatures rose significantly near the end of the Neoproterozoic, perhaps reaching a global average higher than 90° Fahrenheit. (Today's global average is lower than 60°F.)
The tropical Arctic
Another stretch of Earth history that scientists count among the planet’s warmest occurred about 55-56 million years ago. The episode is known as the Paleocene-Eocene Thermal Maximum (PETM).
Stretching from about 66-34 million years ago, the Paleocene and Eocene were the first geologic epochs following the end of the Mesozoic Era. (The Mesozoic—the age of dinosaurs—was itself an era punctuated by "hothouse" conditions.) Geologists and paleontologists think that during much of the Paleocene and early Eocene, the poles were free of ice caps, and palm trees and crocodiles lived above the Arctic Circle. The transition between the two epochs around 56 million years ago was marked by a rapid spike in global temperature.
Around the time of the Paleocene-Eocene Thermal Maximum, much of the continental United States had a sub-tropical environment.
During the PETM, the global mean temperature appears to have risen by as much as 5-8°C (9-14°F) to an average temperature as high as 73°F. (Again, today’s global average is shy of 60°F.) At roughly the same time, paleoclimate data like fossilized phytoplankton and ocean sediments record a massive release of carbon dioxide into the atmosphere, at least doubling or possibly even quadrupling the background concentrations.
Deep ocean temperatures were generally high throughout the Paleocene and Eocene, with a particularly warm spike at the boundary between the two geological epocs around 56 million years ago. Temperatures in the distant past are inferred from proxies (oxygen isotope ratios from fossil foraminifera). "Q" stands of Quarternary.
It is still uncertain where all the carbon dioxide came from and what the exact sequence of events was. Scientists have considered the drying up of large inland seas, volcanic activity, thawing permafrost, release of methane from warming ocean sediments, huge wildfires, and even—briefly—a comet.
Like nothing we’ve ever seen
Earth’s hottest periods—the Hadean, the late Neoproterozoic, the PETM—occurred before humans existed. Those ancient climates would have been like nothing our species has ever seen.
Modern human civilization, with its permanent agriculture and settlements, has developed over just the past 10,000 years or so. The period has generally been one of low temperatures and relative global (if not regional) climate stability. In our next Q&A, then, we’ll tackle this same question on a more Homo sapien-scale time frame: What’s the hottest Earth has been “lately”?
Post by Ken0069 » Thu Oct 05, 2017 12:09 pm
Been wondering how long it would take for this to happen. Looks like this winter may be the beginning.
*La Nina is coming and is likely to impact the upcoming winter, next summer's tropical season, and global temperatures*
October 2, 2017
Overview
Earlier this year, there were signs that a weak El Nino in the tropical Pacific Ocean could continue through the fall and even into the upcoming winter season, but there is now substantial agreement amongst numerous computer forecast models that La Nina conditions are likely to become established over the next couple of months and current observations back this notion. La Nina is a naturally occurring oceanic cycle that produces colder-than-normal sea surface temperatures (SSTs) in the equatorial Pacific Ocean whereas El Nino is associated with warmer-than-normal SSTs. The formation of La Nina in the tropical Pacific Ocean will likely have important ramifications around the world including significant impacts on the upcoming winter season, next summer’s tropical season, and global temperatures.
Read the rest of this article HERE.
The List Rev A =;
Post by Ken0069 » Sat Oct 07, 2017 1:40 pm
Trump Poised to Upend Obama's 'Most Important Climate Regulation'
Cortney O'Brien
Oct 07, 2017 12:15 PM
The Environmental Protection Agency, under President Obama, acted well beyond its authority when it implemented the Clean Power Plan, the Trump administration suggests in a new proposal. The document is expected to be revealed in its entirety by next week.
The Clean Power Plan was introduced in 2015 to minimize power plants' carbon dioxide emissions. It came with a list of regulations intended to steer states away from coal and toward natural gas. It is, Politico notes, President Obama's "most important climate regulation." But, the Trump White House argues it comes with too high a price.
The Trump administration is set to rescind former President Barack Obama’s most important climate regulation, arguing that the greenhouse gas standards for power plants violated federal law and could cost consumers as much as $33 billion, according to a draft proposal obtained by POLITICO.
Think the Trump administration were the only ones to disapprove of the plan? Think again. More than half the country sued the Obama administration over the rule. In April, the Supreme Court suspended the lawsuits, suggesting the plan was nearing its end.
In its draft proposal, the EPA explains that the agency's mission is still to “protect and enhance the quality of the nation’s air resources,” but they must act within the bounds of Congress. The Clean Power Plan does not fit the bill.
“The EPA is proposing to repeal the CPP in its entirety. The EPA proposes to take this action because it proposes to determine that the rule exceeds its authority under the statute, that those portions of the rule which arguably do not exceed its authority are not severable and separately implementable, and that it is not appropriate for a rule that exceeds statutory authority — especially a rule of this magnitude and with this level of impact on areas of traditional state regulatory authority — to remain in existence pending a potential, successive rulemaking process.”
From THIS article.
The List Rev A =;
Post by Ken0069 » Thu Oct 12, 2017 4:46 pm
Global Warming Madness: A Lot Of Pain For No Gain
Date: 12/10/17
Julian Tomlinson
https://www.thegwpf.com/global-warming- ... r-no-gain/
Finally the green madness that’s threatening our ability to turn on the lights and airconditioners is being exposed as a con.
Global temperatures have risen nowhere near the rate at which even the most conservative models predicted, and finally a group of warmist scientists have admitted same in the Nature Geoscience journal last month.
Bear in mind the current mess Australia finds itself in with regards to power generation and business-killing high prices is a result of blindly following these flawed models.
What’s worse is that sceptics have been saying for years the models were wrong, and these people were not only ignored but savaged by warmists, Labor, The Greens and the media.
Don’t hold your breath for an apology from these attack dogs though, that’s never been their style.
Even in Queensland, the story broke this week about the Labor government: “Households and businesses face being told to set their airconditioners to 26C and having power to some hot water systems and pool pumps switched off to save the state from blackouts this summer.”
All because green groups have bluffed politicians into throwing the rest of the population under the bus in a misguided belief we can reverse the world’s temperatures.
The folly of this madness was exposed by former Prime Minister Tony Abbott in a speech this week to the Global Warming Policy Foundation.
He said: “Even if reducing emissions is necessary to save the planet, our effort… is barely-better-than-futile because Australia’s total annual emissions are exceeded by just the annual increase in China’s.”
So due to global warming alarmism, Australia has sacrificed a huge competitive edge of some of the lowest power prices in the world, to now having among the highest.
And yet all this pain and billions of dollars to cut emissions will have absolutely no effect on global climate.
The List Rev A =;
Post by Ken0069 » Sun Oct 22, 2017 10:13 pm
Green Crap: Another Solar Subsidy Business Goes Bust
Date: 20/10/17
Associated Press
A green energy company heavily incentivized by Mississippi is shutting down, raising questions about whether the state will get repaid. It’s the fourth green subsidy company to go bust recently.
Solar panel maker Stion notified the state Tuesday that it would close its Hattiesburg plant Dec. 13, laying off 137 employees.
“Intense, non-market competition from foreign solar panel manufacturers, especially those based in China and proxy countries, has severely impacted the viability of our business,” the San Jose, California, company said in a statement released by spokesman Frank Yang.
Stion is the fourth green energy deal made by former Gov. Haley Barbour to flop. Earlier, solar equipment maker Twin Creeks and biofuel maker KiOR went out of business. Electric car maker GreenTech Automotive has ceased production. Mississippi’s state government is owed at least $92 million by those companies.
Mississippi initially loaned Stion $74.8 million, and state and local governments have given millions more in other tax breaks and subsidies. The company, for example, owes more than $2.1 million in property tax payments, even though tax rates on the plant are two-thirds lower than normal. Stion agreed to start paying down those bills in May, but Forrest County Attorney David Miller said Stion only made three $75,000-a-month payments. […]
Stion raised more than $200 million from private investors, in addition to Mississippi’s loan. It promised 1,000 jobs in Hattiesburg when it announced its plans in 2011. But the company was already struggling in 2013 when venture capital firm Khosla Ventures took a controlling interest. That’s the same company that was the lead investor in KiOR, whose biofuel failure sparked an ongoing lawsuit by Mississippi Attorney General Jim Hood in state court. read more here
The List Rev A =;
GARY C
Post by GARY C » Sun Oct 22, 2017 10:39 pm
Yes, the only solar/wind that will survive are those owned by the big oil companies. This in another one of those where the people are pitted against each other and the solar/wind lovers think they are defeating the big oil companies without realizing that they are actually donating and protesting for the company's that they actually hate.
Here is one example. https://us.sunpower.com/
Note who the parent co is with 66% holdings
https://en.wikipedia.org/wiki/SunPower
Parent co.
https://en.wikipedia.org/wiki/Total_S.A.
David Redszus
Post by David Redszus » Tue Oct 24, 2017 7:16 pm
Name the biggest oil company in the world. ExxonMobil? British Petroleum? Royal Dutch Shell? In fact, the 13 largest energy companies on Earth, measured by the reserves they control, are now owned and operated by governments. Saudi Aramco, Gazprom (Russia), China National Petroleum Corp., National Iranian Oil Co., Petróleos de Venezuela, Petrobras (Brazil) and Petronas (Malaysia) are all larger than ExxonMobil, the largest of the multinationals. Collectively, multinational oil companies produce just 10% of the world's oil and gas reserves. State-owned companies now control more than 75% of all crude oil production....
A mind is a terrible thing to waste...but very useful to manipulate and control.
sanfordandson
Post by sanfordandson » Tue Oct 24, 2017 9:39 pm
Parent co.
I think assuming that anybody who likes solar or wind is an oil hater is very misguided.
David Redszus
Post by David Redszus » Tue Oct 24, 2017 9:53 pm
Solar and wind energy are designed to save us money no matter how much it costs. :lol:
Misguided? Indeed.
sanfordandson
Post by sanfordandson » Tue Oct 24, 2017 10:03 pm
Thats incorrect. [-X
GARY C
Post by GARY C » Tue Oct 24, 2017 10:03 pm
Parent co.
Thats not my point.
The point is many actually believe "big oil evil, big solar good!"
Their one in the same...power and money!
sanfordandson
Post by sanfordandson » Tue Oct 24, 2017 10:17 pm
Thats not my point.
I know what your point was. It doesn't related directly to your misguided view which i pointed out.
