PAC Racing Springs Set of 16 (1329&1356)
FastBuick
Post by FastBuick » Sun Nov 11, 2018 12:33 pm
PAC Racing Valve Springs Set of 16 including PAC-1329 (8 ea.) and PAC-1356 (8 ea.)
This set is ideal in order to equalize coil bind clearance and spring pressures on both intake and exhaust for camshafts that have more intake lift than exhaust lift.
This is a matched set and was used with the 1329s on the intake and 1356s on the exhaust.
All springs have been tested and match factory specs. They have very lows runs on them and are in very good condition. This set is $640 new. Selling for $275.
PAC-1329 Dual Springs
Outer Spring Diameter 1.500"
Installed 350# @ 2.100"
Open 1052# @ 1.200"
Coil Bind 1.130"
Rate 780 lbs./in.
Max Lift .900"
PAC-1356 Dual Springs
Installed 300# @ 2.100"
Open 1002# @ 1.200"
Coil Bind 1.130"
Rate 780 lbs./in.
Max Lift .900"
If you have any questions, or need more specs please contact me.
PAC Racing Springs Authorized Dealer
Independent T-1 Certified Amsoil Dealer
Wix Filters Dealer
