1964 327 Corvette block crank and 461X heads
I have a 327 block that codes out to a 1964 corvette ragtop, 365 hp manual trans AC car...Block has been baked, magnafluxed and fully prepped (bored .030 honed in deck plates, "0" decked up to the stamped pad and line bored w arp main bolts) by Carl Hinkson at CNC BLOCKS NORTHEAST...the stamp on the deck is F0I06RR and 4111551 the date code is A 34....The heads are 461X heads date coded c 22... 2.02 and 1.6 Manley valves w/ new K-line bronze guide liners, screw in studs and guide plates and the spring pockets opened for bigger springs, crank is forged it was magnafluxed and ground .010/.010....will separate...call Tom @ 1-508-400-1726 or Email @ Tkelly1550@yahoo.com
