Page 1 of 1
WTB Y Block Ford Parts
Posted: Sun Jun 11, 2017 6:27 pm
by liqu
Ported heads for a Y Block Ford, steel cranks, or any other modern (if possible) speed equipment (no 3x2 manifolds) good or bad.
Re: WTB Y Block Ford Parts
Posted: Mon Jun 12, 2017 1:36 pm
by BirdMan
I believe I have a stock 292 crank if you are int.
Posted: Mon Jun 12, 2017 3:50 pm
by liqu
Hi, I am looking for steel cranks, steel cranks have no center counter weight, and the flywheel flange is round (no 1/2 moon cut out)
Posted: Thu Jun 29, 2017 11:23 pm
by pdq67
liqu wrote:Hi, I am looking for steel cranks, steel cranks have no center counter weight, and the flywheel flange is round (no 1/2 moon cut out)
Didn't the old 292" truck engines have SOME forged cranks in them?
Posted: Fri Jun 30, 2017 7:59 pm
by liqu
Yes, most 3/4 ton and up, 1961 and newer trucks have a steel crank, however most will need a snout repair (loose damper)
