WTB Y Block Ford Parts
liqu
Post by liqu » Sun Jun 11, 2017 6:27 pm
Ported heads for a Y Block Ford, steel cranks, or any other modern (if possible) speed equipment (no 3x2 manifolds) good or bad.
BirdMan
Re: WTB Y Block Ford Parts
Post by BirdMan » Mon Jun 12, 2017 1:36 pm
I believe I have a stock 292 crank if you are int.
Dale C.
liqu
Post by liqu » Mon Jun 12, 2017 3:50 pm
Hi, I am looking for steel cranks, steel cranks have no center counter weight, and the flywheel flange is round (no 1/2 moon cut out)
Post by pdq67 » Thu Jun 29, 2017 11:23 pm
liqu wrote:Hi, I am looking for steel cranks, steel cranks have no center counter weight, and the flywheel flange is round (no 1/2 moon cut out)
Didn't the old 292" truck engines have SOME forged cranks in them?
liqu
Post by liqu » Fri Jun 30, 2017 7:59 pm
Yes, most 3/4 ton and up, 1961 and newer trucks have a steel crank, however most will need a snout repair (loose damper)
