RCD Crank Hub and Trigger Ring with Magnents for BBC
Procharged 434
Post by Procharged 434 » Fri Apr 21, 2017 10:50 am
Here I have a good used RCD Engineering 7" Degree Wheel and hub. The degree wheel has the Magnents to use for a crank trigger setup, and the hub is for BBC snout and has dual 1/4" keyways. The pulley bolt pattern is 6-bolt, common blower pulley pattern. I bought this new from RCD, and has maybe 15 1/8 mile passes on it, was over $300 new. Has normal nicks and scratches from being used, **NOTE** MUST BE USED WITH A BELT DRIVE SETUP**, we had to have it machined down to work with our belt drive bottom crank pulley, so it will not work with a standard cover and seal, but will work with any belt drive setup.... Asking $165 Shipped. I will only ship within the U.S. and I only accept PayPal for payment
Thanks
