BBC parts.
Posted: Sat Jan 14, 2017 1:35 pm
FAST Crank Trigger Kit P/N # 301180 CRANK TRIGGER; BIG BLOCK CHEVY W/ 8" BALANCER Includes all required mounting hardware; plug & play w/ most aftermarket carburators and EFI systems. Ultra durable CNC-machined aluminum bracket w/ clearly labeled precision timing marks. Small OEM quality inductive sensor provides unrivaled accuracy while saving space. Magnet-free, ultra-thin .125" thick steel wheel. New In the box . $175 OBO
TCI Rattler harmonic balancer damper Chevy 454-502 it's external balanced. Part number 870006 in excellent condition. $225
Clevite H-Series Main Bearings. MS-829H Chevy big blocks all STD set. Performance narrow bearing for stock or stroker cranks. New set never opened. $75
Clevite H-Series Rod Bearings. CB-743HN Chevy Big Blocks all STD set. New never opened. Performance narrow bearings.For all eight bearings $110
Fel-Pro Performance Rear Main bearing Seal part number 2904. New in skin package. All big block chevy engines Rear Main Seal, 2-Piece, Silicone $15
Big Block Chevy header gaskets. NEW. For all make of headers. Fit better there thick less chance of burn thru. Made by Doug headers. # HG9303 $20
Chrome water outlet like new Proform with O ring seal. For all sbc and bb chevy's intakes $10
New Polished Billet aluminium big block Chevy single groove water pump pulley deep grove V belt. Fits the long water pumps. Made in the U.S.A Never used or mounted. $60
GM Stock Big Block Chevy single groove V belt pulley for the long water pump $20
Edelbrock Victor Series Mechanical Water Pumps 8851 For all big block chevy long water pump.
Light weight aluminium mechanical water pump. Like new does not leak. Clean ready to bolt on.
You get new gaskets with it. $140
J.W. Performance The Wheel Flexplate 93004 for Big Block Chevy's 454 thru 502 its external
balanced. 168 tooth SFI. For automatic trans thick one. All teeth are in perfect condition. With ARP Pro Series Flexplate Bolt part number #200-2902 $125
Have photos of all parts.
Text/ 7737153800
Thanks.
Text/ 7737153800
Thanks.
