Race Pump and Regulator Needed
I know these never caught on, however, I need a few for a special application. The Manf. has told me that they are done making them, as he sold the last one he had in stock. I will take a USED one if anyone has one or two. This is a piston type pump that bolts onto the block in the stock Chevy fuel pump location and is actuated by the fuel pump pushrod. Anyone have any they are stuck with or tried ? The Professional Products people [The Chinese Knockoff Manifold Manf.] Also made a similar type of pump/regulator, but they to have stopped making/importing them. Please let me know what you have! Thanks Al
Some people are so stupid that they dont even know it! - by a famous Hillbilly
Re: Race Pump and Regulator Needed
While there is other pumps available they stopped making that pump because 99% of them failed and jammed.I personally tried seven of them and they all failed.
Can you not use an electric pump ??
No It must be a mechanical unit and this is the only unit that will fit in the given space with enough capacity. It pumps Methanol. Do you have an of the failed units and the regulators laying about? thanks Al
Sorry
My supplier dropped that line several years ago. of the 250 they sold I am told 248 were returned as defective..
There is several electric pumps suitable for alky depending on the carb/carbs requirements.
I have a lightly used pump and regulator. Also believe I have a new pump in the box I bought for a spare. Let me locate everything.
You have a PM-RE race pumps and Regulator. Thanks Al
I have a pump and regulator I bought used and moved to a class where we could run belt drive. If you are interested PM me.
Nick you have a new PM today. Thanks Al
