parts have only dyno time on them and more pictures can be taken if you pm me a request. i can ship everything.
i had these in my 397 turbo stroker lt1 with afr 210cc heads these are the baddest parts you can put into a head besides shaft rockers which is what i decided to do go. these is nothing wrong with anything listed and has little to no wear visible! all parts ran in comcams break in oil then royal purple at the dyno i also have all the boxes as well. will work in sbc pm any question i will answer thanks.
COMP Cams Ultra Pro Magnum XD Roller Rocker Arms 1805-16
$350.00 http://www.summitracing.com/parts/cca-1805-16
COMP Cams Hi-Tech Pushrods 8461-16
$150.00 http://www.summitracing.com/parts/cca-8461-16
COMP Cams Rocker Arm Adjusting Nuts 4508-16
$75.00 http://www.summitracing.com/parts/cca-4508-1
AFR stud girdle 6201
$120.00 http://www.summitracing.com/parts/afr-6201
Isky Adjustable Guide plates 300-AGP
$50.00 http://www.summitracing.com/parts/isk-300-agp
ARP 7/16" Rocker Studs AFR #6405
$45 http://www.airflowresearch.com/shopp...rt.php?sort=3a
Trick Flow Chromoly Pushrods TFS-21407850 (these do have a a few thousand miles on them and only these)
$60 http://www.summitracing.com/parts/tf...7850/overview/
compcams vlave train and afr girdle
Re: compcams vlave train and afr girdle
Bump!! Any offers?
Open to offers
PRICE REDUCED
i had these in my 397 turbo stroker lt1 with afr 210cc heads these are the baddest parts you can put into a head besides shaft rockers which is what i decided to do. these is nothing wrong with anything listed and has little to no wear even visible! all parts ran in compcams break in oil then royal purple at the dyno i also have all the boxes as well. will work in sbc heads pm any question i will answer thanks.
Only selling because I went to t&d shaft mounted rockers
$290 http://www.summitracing.com/parts/cca-1805-16
$125 http://www.summitracing.com/parts/cca-8461-16
$65.00 http://www.summitracing.com/parts/cca-4508-1
$90.00 http://www.summitracing.com/parts/afr-6201
$40.00 http://www.summitracing.com/parts/isk-300-agp
$45 http://www.airflowresearch.com/shopping ... hp?sort=3a
$60 http://www.summitracing.com/parts/tfs-2 ... /overview/
Rockers and studs are SOLD!
Compcams adjuster nuts SOLD!!!
