I've got an assortment of AN fittings in -8 and -10.
There is a little over 6' of -10AN braided steel line
Numerous -8AN fittings of various manufacture (5 - female hose ends, 5 - 3/8 NPT to - 8AN male, 1 - male/male union, 2 - Holley carb fittings to -8AN without O-rings, 3/8 NPT to -8AN male with 1/8 NPT plug)
Numerous -10AN fittings of various manufacture (2 - female unions, 1 - male union, 1 - 1/2 NPT to -10AN)
3 Holley carb fittings (inverted flare) no o-rings
Hydroboost lines for an A-body conversion. The lines are just a tick over 2' and are -6AN with the exception of the flare fitting for the pump. Aluminum brackets are included. These are from Tallon hydraulics. They came with the used hydroboost conversion kit I purchased but I elected to run black rubber hose instead of these.
Most of the fittings show signs of use. The fittings that are sitting on the plastic bags are new. Hopefully the pictures provide enough detail.
I'd prefer to sell all in one lot for $100 TYD. Email reetodded540 <at> yahoo.com for quickest response.
Thanks for looking.
Lot of AN fittings, hose and hydroboost plumbing
