Vortec/Edelbrock TPI
dfarr67
Post by dfarr67 »
Edelbrock Hi Flow Vortec TPI base and runners with functioning egr valve and corvette EGR takeoff, fuel rails, oe fuel pressure regulator, Multec injectors (cores). Gasket matched and casting flash cleaned up- no major porting effort. Oem ported plenum. Comes with all vacuum ports and hei cover and vortec intake gaskets, new fuel rail o-rings. Needs bolts. $645
Ford/Bosch gen-4 24lb injectors- barely used, modified for GM fuel rail. USCAR connector pigtails included. 280-158-138, 7C3E-AB. $250
Edelbrock 1910 Performer RPM Q-Jet carb, 850 cfm, Cliff's Performance (Ruggles) carb kit. $450
Upcoming package- Crower Enduro SS roller rockers 3/8in x 1:6 self aligning very good condition, lightly used LS7 roller lifters, OEM vortec roller cam (excellent core for regrind) $350
