830 Holley Alky Carb + Russell Fittings
Bad78Cutlass
Post by Bad78Cutlass »
830 Holley/Quickfuel Alcohol Carburetor
- NEW Quickfuel Alcohol Metering Blocks.
- NEW Quickfuel Alcohol Bowl Extensions.
- NEW Quickfuel 50cc Aluminum Pump Housings.
- NEW Fuel Bowl Screws.
- NEW .600" ID Annular Boosters.
- NEW Reusable Gaskets & Washers.
- Milled Choke Horn.
- 4 Corner Idle Adjustment.
- .035 Pump Nozzles w/ Hi Flow Screws.
- #152 Primary Main Jets w/ 6.5 PV.
- #172 Secondary Main Jets w/ Blocked PV & Jet Extensions.
NEW RUSSELL FITTINGS
(2) 12AN Straight Hose Ends.
(3) 8AN Straight Hose Ends.
(2) 6AN Straight Hose Ends.
(1) 10AN Straight Hose End.
(1) 8AN Flare Union Male/Male.
(1) 6AN Flare Union Male/Male.
(1) 6AN 90* Hose End.
(1) 6AN x 3/8 NPT Adapter.
(1) 6AN x 1/4 NPT Adapter.
(1) 8AN x 1/2 NPT Adapter.
(1) 8AN x 3/8 NPT 90* Adapter.
CARB - $400 FIRM + $17.90 to ship
ALL FITTINGS (will not seperate) - $113 Shipped
PM or Text (614) 556-6656. Located in Columbus, OH. Will ship anywhere in the U.S.
Will accept PayPal, Wal-Mart Wire Transfer, Money Order.
Compton Bros. 408 SBC on E85 - 10.07 @ 131 - 6.36 @ 107 All motor ~ 3190lb
Bad78Cutlass
Re: 830 Holley Alky Carb + Russell Fittings
Carb is sold, fittings are still available.
Bad78Cutlass
Fittings sold...
