*750 CFM Holley HP #80535 Alcohol Carburetor*
- 4 Corner Idle Adjustment.
- Downleg Boosters.
- Screw In Replaceable Air Bleeds.
- Dual 50cc Acc Pumps.
- Non Stick Gaskets.
- Nylon Washers.
- Alcohol Compatible Diaphragms.
- #150 Main Jets.
- Blocked PV's.
- .055" Pump Nozzles.
- Dual Inlet HP Fuel Bowls.
$425 FIRM.
Call/text 614-556-6656 for a quicker reply if your interested or have any questions. Thanks....
750 Holley HP Alcohol Carb
Compton Bros. 408 SBC on E85 - 10.07 @ 131 - 6.36 @ 107 All motor ~ 3190lb
Re: 750 Holley HP Alcohol Carb
$350
Sold
