*HP 775 CFM "RS" Demon ALKY CARB*
- Removeable Venturi Sleeves.
- Sleeve Color: RED. Thid carb can be 1,000+ CFM with correct sleeves.
- Demon Black Billet Alcohol Metering Blocks.
- Billet Baseplate.
- Replaceable Screw In Air Bleeds.
- 4 Corner Idle Adjustment.
- Downleg Boosters.
- .150" N&S Assemblies.
- #140 Main Jets.
- .040" Pump Nozzles.
- NEW Non Stick Gaskets.
- Nylon bowl bolt washers.
- Large Sight Glasses.
- Large Capacity Float Bowls.
*750 CFM Speed Demon GAS CARB*
- Mechanical Secondaries.
- Downleg Boosters.
- Billet Metering Blocks.
- Billet Baseplate.
- Hi Flow Choke Tower Housing.
- .110" N&S Assemblies.
- .031" Pump Nozzles.
614-556-6656 ~ RS carb is $500 and the Speed Demon is $300
Demon Carburetors For Sale
Compton Bros. 408 SBC on E85 - 10.07 @ 131 - 6.36 @ 107 All motor ~ 3190lb
Re: Demon Carburetors For Sale
750 Speed Demon has been sold.
The 775 RS Demon is still available
$400 for the RS Demon
Sold
