#80496 Holley 950 HP Carburetor
- Gas Carb.
- Downleg Boosters.
- 4 Corner Idle Adjustment.
- Screw In Replaceable Air Bleeds.
- Dual Inlet HP Fuel Bowls.
- BLP "325" SS Throttle Plates w/ Button Head Screws.
- 30cc Acc. Pumps.
- #82 Main Jets.
- 4.5 PV's.
- .032" Main Air Bleeds.
- .072" Idle Air Bleeds.
- .031" Pump Nozzles.
- Non Stick Gaskets.
- NEW Nylon bowl bolt Gaskets.
- Jet Extensions w/ Notched Rear Float.
#7320 Holley 1150 Dominator
- Gas Carb.
- 2 Circuit Metering.
- 8 Hole Annular Boosters.
- #96 Primary Main Jets.
- #97 Secondary Main Jets.
- Blocked PV's.
- .031" Primary Pump Nozzle.
- .035" Secondary Pump Nozzle.
- NEW Vent Tubes.
- NEW 50cc Acc. Pump Housings.
- NEW Acc. Pump Diaphraghms.
- NEW Red Non Stick Gaskets.
- NEW Hi-Flow Nozzle Screws.
- NEW Acc. Pump Arms.
- NEW Viton .120" N&S Assemblys.
- NEW Brass Sight Plugs.
- NEW (1) Brass Float.
- NEW Nylon N&S Gaskets.
- NEW Bolts (All expect bowl bolts)
- NEW Nylon Gaskets on bowl bolts.
- Hand Smoothed/Polished Venturis, Booster Inserts, and Fuel Bowls.
1150 CFM Holley E85 Dominator.
- List # 7320
- E85 Calibrated Billet Metering Blocks (requires 5/16 x 32 main jets)
- BLP 18 Hole Billet Annular Boosters.
- BLP .140 N&S Assemblys.
- BLP Vent Tubes.
- BLP Main Jets.
- 50cc Alcohol Diaphragms.
- Alcohol Compatible Diaphragms.
- Nylon Gaskets on fuel bowl bolts.
- Smoothed & Polished Mainbody.
- 8-32 Screw In Replaceable Air Bleeds.
- Tapped Mainbody faces for 8-32 replaceable T-Slot Restrictors.
- Hand Drilled .045 Pump Nozzles.
Carb works great on the street or strip. Exellent throttle response. Has alittle street driving and 8 passes on it. Believe it's too big for my 406 so I'm going to build a 1050. Carb is still on my engine.
1 of a kind carb, won't find another like it.
950 GAS - $450
1150 GAS - $600
1150 E85 - $800
I will also Partial Trade on each carb. I'll take 4150-4500 Gas, Alcohol, E85 Carbs + CASH. N20 Systems + CASH, etc. I won't trade down or even.
Holley HP 950 - Holley 1150 - E85 1150
Compton Bros. 408 SBC on E85 - 10.07 @ 131 - 6.36 @ 107 All motor ~ 3190lb
Re: Holley HP 950 - Holley 1150 - E85 1150
614-556-6656 Call/Text Justin - If interested or have any questions feel free to ask...
Gas 1150 is gone.
For 5 days only, I'll let the 950 HP go for $313 shipped.
Holley HP 950 has been sold.
E85 1150 is gone...
