BBC solid rollers
BBC solid rollers
comp custom grind 260 / 270 @ .050 .670 / .670 lift 110 LSA
Chris Straub custom grind 247 / 254 @ .620 / .640 lift 107 LSA
Both cams have gen 5 snout for use with a thrust plate. $260 shipped to USA or Canada. Located in Canada
email brianj_taylor@hotmail.com or phone 306-752-5558
Re: BBC solid rollers
Both cams still available $250 shipped to USA. The comp cam is billet and the CS cam appears to be cast.
Specs on Chris Straub cam are as follows:
279 / 290 or 248/260 @ .050
lift .638 intake, .619 exh with 1.7 ratio rockers
107 LSA
Sorry for the confusion. This cam was chosen based on a pump gas 489 with AFR 325 heads. I have all the opening and closing numbers as well. I never realised the full potential of this cam and i would be very curious to see it work in someone else's engine and what they gain.
107 LSA
Lowering price. $230 US dollars shipped to USA for either cam. I want to buy a new cam for a much different motor but i need to sell these first. Pay by paypal or mail me a cheque or money order.
Brian
Brian
yes both cams are still available
Can you post the part # or lobe numbers for the Comp cam? Sending you a PM. Thanks.
i have the cam card if you give me your email i can send it to you.
Comp cam sold locally. Straub Cam still available.
Interested in the CS cam.
What is the rpm range and lash?
Do you have a can card or paperwork for the cam?
yes i have everything, whats your email adress?
Intake Duration - ID 279 (248 at .050)
Exhaust Duration - ED 290 (260 at .050)
Lobe Center Angle - LCA (also known as LSA) 107
Intake Centerline - ICL 101
Intake Valve opens - IVO 38.5
Intake Valve closes - IVC 60.5
Exhaust Valve Opens - EVO 78
Exhaust Valve Closes - EVC 32
Exhaust Centerline - ECL 113
Overlap 70.5
Lobe Lift intake .375
Lobe lift exhaust .364
Overlap 70.5
