*Holley 850 HP Alcohol Carb Modified by Barry Grant*
- Replaceable Screw In Air Bleeds.
- 4 Corner Idle Adjustment.
- HP Fuel Bowls w/ Dual Inlets.
- Barry Grant Bowl Extensions.
- .052 Pump Nozzles.
- #164 Main Jets w/ Jet Extensions.
- 30cc Acc. Pumps.
- Alky Pump Diaphragms.
- New Nonstick Gaskets.
- New O-Rings on N&S.
- Nylon Washers on bowl bolts.
- "BG" is engraved on top of the mainbody. Work # is engraved on the side.
Have pictures upon request. Very nice carb...$600 OBO - Or partial trade on 4150 HP or 4500 HP...614-556-6656 ~ onebadolds@yahoo.com
Holley/BG 850 Alky Carb
Re: Holley/BG 850 Alky Carb
Picture of the carb....Still Available!!
Compton Bros. 408 SBC on E85 - 10.07 @ 131 - 6.36 @ 107 All motor ~ 3190lb
EDIT:
I was wrong, it is a 950 carb. I assumed it was an 850 of just going by the #180 butterflies. The main body has a part number, and it is a body that converts a 4781 to a 950. Bottom of the main body measures 1-3/4 and the venturi measures 1.400".
Main body part number: 6R-7867-B
I should of checked that when I first got it, I've had alot of things going on lately and never double checked it. PRICE IS STILL THE SAME....
