Garage Sale Part 2! Many More Parts Added and All Must Go!
Brand new Titan Pro Series External Oil Pump $825
http://www.racingjunk.com/Oil-Pumps-Pan ... -Pump.html
Barry Grant 1295 King Demon RS Drag Race Calibration Carb Part# 9849020DR $675
http://www.racingjunk.com/Carburetors/1 ... -Carb.html
Barry Grant BG280 Fuel Pump $175
Brand new Pro Systems Pro Series High Flow Regulator $50
Mallory Comp 250 Fuel Pump part# 5250 $175
Mallory Fuel Regulator part# 4207 2 available $40 each
Jesel SBC Belt part#30990 $35
Jesel BBC belts part# 31010 5 available $35 each
Simpson 5 point harnesses part#29073BK 2 available $40 each
JE 52 Series Wrist Pins SBC .927"x2.750" part# 927-2750-15-52S 2 sets available $60 each
JE 52 series wrist pins BBC .990"x2.930" $60
Crane Cams Pro Series Roller Lifters for BBC part# 13542-16 $125
Crane Cams Ultra Pro Roller Lifters for BBC part# 13570-16 $175
PAC Racing Valve Springs part# PAC-1356 1 set available $225
Outer Spring Diameter 1.500"
Installed 300# @ 2.100"
Open 1002# @ 1.200"
Coil Bind 1.130"
Rate 780 lbs./in.
PSI Valve Springs part# DR1224 3 sets available $100 each
Outer Spring Diameter 1.625"
Installed 275# @ 2.000"
Open 750# @ 1.200"
Coil Bind 1.130"
Rate 594 lbs./in.
Xceldyne Titanium Retainers part# XRE524-LTW 3 sets available $175 each
Big Block Chevy Internally Balanced Rotating Assembly
Scat Forged 4340 4" Stroke Crankshaft
Carrillo 6.135" Billet Steel Connecting Rods with 7/16" WMC H-11 Tool Steel Rod Bolts
JE 4.280" Bore 9.780" Deck Height Gas Ported Dome Pistons with upgraded JE Wrist Pins, coated skirts, and thermal coated tops
Total Seal Maxseal Gapless Rings
Internally Balanced
This rotating assembly is already balanced and ready to go.
$1100
4 bolt main L-88 BBC block part#14015445 $400
MSD 7AL-2 Ignition System part# 7220 $225
MSD Timing Computer part# 8980 $75
MSD 2-step part# 8739 $35
MSD Pro Billet Distributor part# 85551 $125
Canton BBC Drag Power Pan with Canton Oil Pump Pickup $145
Melling Select BBC Oil pump part# 10778C $60
Melling Select BBC Oil Pump part# 10770 $50
Brand New Hurst Electric Solenoid Shifting Kit part# 2260020 $125
All GM Performance Parts
Part#
12551483 Valve Springs for ZZ3/ZZ4 heads 16 ea. $20 for 16
12371043 Single Roller Timing Chain Kit $35
14088783 Timing Chain 2 available $25ea.
12371041 Pushrod Kit $25
12495497 Screw in rocker stud kit GM Fast Burn Heads $30
Buyer pays shipping.
If you have any questions, want more information, or would like some pictures please contact me. You can reach me by calling/texting me at 570-510-2811 or PM me here.
Let's make a deal! All prices are negotiable. Make offers if interested. And if you buy multiple items I can sweeten the deal more.
I do accept PayPal and all other forms of payment including credit cards.
Thanks
Open 1002# @ 1.200"
Coil Bind 1.130"
Rate 780 lbs./in.
Open 750# @ 1.200"
Coil Bind 1.130"
Rate 594 lbs./in.
Internally Balanced
$1100
Part#
Thanks
PAC Racing Springs Authorized Dealer
Independent T-1 Certified Amsoil Dealer
Wix Filters Dealer
Wix Filters Dealer
Re: Garage Sale Part 2! Many More Parts Added and All Must G
Where in Pa are you located?
results speak for themselves
Just sent you a PM.ClassicComp wrote:Where in Pa are you located?
Thanks
Wix Filters Dealer
Wix Filters Dealer
Big Block Chevy Internally Balanced Rotating Assembly is Sold.
Thanks
Thanks
Wix Filters Dealer
Wix Filters Dealer
MSD Pro Billet Distributor part# 85551 Sold
Make offers on any remaining parts.
Thanks
Thanks
Wix Filters Dealer
Wix Filters Dealer
What's been done to the 445 block, and what are the part numbers on the Canton pan & pickup?
Thanks.
Thanks.
Just sent you a PM.VMC wrote:What's been done to the 445 block, and what are the part numbers on the Canton pan & pickup?
Thanks.
Thanks
Wix Filters Dealer
Wix Filters Dealer
MSD 7AL-2 ignition system part#7220 SOLD
Wix Filters Dealer
Wix Filters Dealer
Barry Grant 1295 King Demon RS is SOLD
Thanks
Thanks
Wix Filters Dealer
Wix Filters Dealer
Barry Grant BG280 fuel pump is SOLD.
Thanks
Thanks
Wix Filters Dealer
Wix Filters Dealer
Mallory Fuel Regulators part# 4207 are both SOLD
Thanks
Thanks
Wix Filters Dealer
Wix Filters Dealer
MSD 2-step part#8739 is SOLD
Thanks
Thanks
Wix Filters Dealer
Wix Filters Dealer
Crane Cams Pro Series Roller Lifters for BBC part# 13542-16 are SOLD
Thanks
Thanks
Wix Filters Dealer
Wix Filters Dealer
Simpson 5 point harnesses part#29073BK are SOLD.
Thanks
Thanks
Wix Filters Dealer
Wix Filters Dealer
Melling Select BBC Oil Pump part# 10778C is SOLD.
Thanks
Thanks
Wix Filters Dealer
Wix Filters Dealer
