Will fit all 1st gen Camaro's 67 to 69 as well as nova 68 to 72
1969 Camaro Z28 front Subframe. Straight, never wrecked, Set up is for a LS motor and comes with the LS motor mounts. Close ratio Steering box is tight. Suspension is kit from Global One.
http://www.summitracing.com/parts/gls-c ... 7AodnzsABg
Wilwood disc brakes. Wheels and tires are not included. Came out of a very nice running and driving car. It has the Global West Suspension Category 5 Suspension Kits CNR-79H13-4 already set up in it with coil over shocks and Wilwood disc brakes. Ready to bolt right up to your camaro. Will also fit 1968 to 1972 Nova's. I have over $7,000 into this set up with the global west kit, Wilwood disc bracks and all the mods done to the frame for the LS set up. $3500. Here is your chance to save more then half. I also have a 6 speed manual trans I'm selling. It will fit all 1st gen Camaro's
FOR SALE 1967 1968 1969 Camaro Global West LS front Subframe
