WANTED 7.900 3/8 pushrods
Looking for good quality name brand, new or used, 3/8 7.900 pushrods with the 210degree ends. Let me know what you have.
Re: WANTED 7.900 3/8 pushrods
I have a new set of GM Performance Parts pushrods. I believe that is the length and diameter. I will double check the length and diameter later. Message me here or call me at 570-510-2811 if you are interested.
Thanks
Thanks
PAC Racing Springs Authorized Dealer
Independent T-1 Certified Amsoil Dealer
Wix Filters Dealer
Wix Filters Dealer
See ad below ".904" Chilled Iron..." I have 3/8" that are 7.850" and 7.825" if that will work and I also have 5/16" that are 7.900".
NHRA SS/G
1970 AMC AMX - 390 4-speed
You only have 8 of the 7.850 it looked like, waiting to get heads back from being angled milled but ususally this combo likes the 7.900. I called smith brothers and found a set for around $10 each new. I for sure want 3/8. Let me know what size you have fast buickJeff Lee wrote:See ad below ".904" Chilled Iron..." I have 3/8" that are 7.850" and 7.825" if that will work and I also have 5/16" that are 7.900".
Ok I will check shortly when I get home from work and let you know exactly what size they are.
Wix Filters Dealer
Wix Filters Dealer
I'm sorry, the ones I have are too short for you.
Wix Filters Dealer
Wix Filters Dealer
racinnut15xm wrote:You only have 8 of the 7.850 it looked like, waiting to get heads back from being angled milled but ususally this combo likes the 7.900. I called smith brothers and found a set for around $10 each new. I for sure want 3/8. Let me know what size you have fast buickJeff Lee wrote:See ad below ".904" Chilled Iron..." I have 3/8" that are 7.850" and 7.825" if that will work and I also have 5/16" that are 7.900".
Why the hesitation at $10 each?
-Carl
-Carl
Only hesitation is knowing for sure its what i need. Waiting on machine shop to finish the angle mill then gotta put them back together to know for sure thats what i need. I have a set of 8.000's right now. They were certainly cheaper for a similiar push rod than manton or most of the box store places. If i buy new thats where i will be going.
