.904" Chilled Iron lifters, Billet Rods, flat tappet, roller
Jeff Lee
Post by Jeff Lee »
Selling extra parts from my AMC stash. AMC is oil through pushrod. Other applications may work.
Rods are AMC / SBC.
Rockers are AMC / Ford.
All Prices include free shipping to continental USA. PayPal users add 4%.
I have measured the O.D. of the lifters.
Let me know what you need. Please call Jeff @ 602-418-9797 or JeffLeeAzRealty@gmail.com
Thank you.
1) – SOLD –
Isky quiet Power #3052-HY - AMC Anti-Pump-Up Hydraulic Lifters.
Condition: New in Box.
Quantity: 18.
Measure .9045" O.D.
"Isky's patented Superlifters outwardly appear similar to standard hydraulic lifters, but there's a world of difference. The design of the lifters allows the use of a more radical cam, without loss of compression and horsepower from
valves being held off their seats. Because they don't bleed down completely, they are also far more durable and reliable than any other lifters on the market."
New Summit Racing price: $154.07.
Selling with free shipping: $115.00.
2) Sherman Racing Products - AMC Anti-Pump-Up Hydraulic Lifters.
Quantity: 16.
Measure .9038" O.D.
Used in high performance lifter rule classes such as NHRA / IHRA Stock Eliminator and various circle track applications. Suitable for street use.
Plunger travel .020" to .025" with valve setting of .000" to -.005".
Sells new for approximately $270.00
Selling with free shipping: $165.00.
3) Comp Cams Solid Roller Link style lifters p/n 848-16.
Condition: Used. Guaranteed to your satisfaction. Offering 1-week look see (call for details).
Quantity: 16.
Measure .9032" O.D.
My cam was .801" lift w/ T&D shaft rockers; 75 runs and no problems. Wheel bearings are excellent. These are rebuild able. New price is around $500.00 per set.
Selling with free shipping: $195.00.
4) Schubeck “Hydraulic” Lifters with Composite "puck".
Quantity: 16.
Measure .9032" O.D.
Condition: Used / slight scuffing on steel body, will polish out.
Run outrageous spring pressures on your "hydraulic" cam profile. Typical use with open pressures are 440-480#'s with no wear.
New pricing around $800.
Selling with free shipping: $450.00.
5) Isky Chilled Iron Lifters
Quantity: 27
Condition: 16 used / perfect, 11 new.
Measure: .9045"
Converted to "hydraulic" to satisfy NHRA / IHRA mandated .015" minimum lifter plunger travel. Can be made full solid.
From Isky Glossary of Terms:
"CHILLED IRON LIFTER: A cam follower made from high quality iron alloy that is heat treated by pouring the molten iron into a honeycomb mold with a chilled steel plate at the bottom to heat treat the face of the lifter. It's compatible with steel and hardface overlay cams only."
Newspaper packaging in this box is dated August 19, 1970. I bought these lifters from Ron Iskenderian around 2000-2002? He found them in the attic and said that was the last set. I know they are impossible to find so I bought everyone he had. Ron told me the EPA banned the manufacturing process in the 1980's? I ran these on a steel billet cam. There is not a better .904" solid or hydraulic lifter made and nothing to break. Will not break up the set. These are in PERFECT condition.
Selling 27 with free shipping: $550.00.
6) Manley or Smith Brothers (?) Pushrods - #2805. 7.850” x 3/8”. Quantity: 8.
Condition: Used /perfect condition.
New price around $120.
Selling with free shipping: $90.00
7) Manley or Smith Brothers (?) Pushrods - #3203. 7.825”” x 3/8”. Quantity: 8.
Condition: Used / perfect.
8) Manley Pushrods - #25712. 7.900” x 5/16” .080” wall 4130 CM.
Quantity: 16.
“Manley pushrods are the perfect complement to your Hot Street, bracket, oval track, or any other high performance engine. These one-piece pushrods are made of chromoly steel, have .080 in. wall thickness, and are heat-treated for use with guideplates. They're an affordable way to combat higher spring pressures and the other stresses associated with high performance engines.” New Summit Racing price: $143.97
Selling with free shipping: $80.00
9) Manley 4130 CM Pushrods - #25716. 8.00” x 5/16” .080” wall.
Quantity: 16.
10) Comp Cams Hi-Tech 4130 CM Pushrods - #7997 8.100” x 5/16” .080” wall.
Quantity: 16
“As cam profiles get more aggressive and valve spring pressures increase, it is even more critical to select the right pushrod for your application. COMP Cams Hi-Tech pushrods are designed using high-quality premium steel alloy for a lifetime of strength and durability. Hi-Tech pushrods from COMP Cams' advanced technology keep you competitive in a high-tech world”.
New Summit Racing price: $139.97
Selling with free shipping: $75.00
11) Comp Cams Hi-Tech 4130 CM Pushrods - #7972 7.800” x 5/16” .080” wall.
Quantity: 16
Selling with free shipping: $75.00.
12) Comp Cams Ultra Pro Magnum Roller Rocker Arms – #1632-16
Quantity: 1 set of 16.
Application: AMC / SBF Windsor. 7/16” stud. 1.6 Ratio.
“Utilizing years of valvetrain design experience, the latest FEA stress analysis technology, and an exhaustive testing regiment (dyno and Spintron), the COMP Cams engineering team left no detail to chance. Everything from casting techniques to valve spring clearance was scrutinized to ensure that the new Ultra Pro Magnum rocker arms not only lived up to the lofty standards of their predecessor, but also took stud mount rocker performance, stability, and value to a whole new level.
The most noticeable advancement with the COMP Cams Ultra Pro Magnum rocker arms centers around their nearly unbreakable investment cast 8650 chromoly body. The arched, web-like design delivers a nearly 29 percent increase in strength and rigidity, while reducing the moment of inertia and optimizing the dynamic balance. The resulting rockers maximize lift and valvetrain control at high rpm. The increased retainer and valve spring clearances of the new design enable the use of large-diameter valve springs, retainers, and locks, without clearance or fitment issues. The new black oxide exterior finish offers a distinctive appearance, along with long-term corrosion resistance. The COMP Cams Ultra Pro Magnum rocker arms feature an oversized trunnion and precision-sorted needle bearings designed for use with high-load valve springs. Additionally, these unique rockers also feature hardened roller tips for reduced friction and elimination of the valve stem "side loading" that causes premature valve guide wear. The COMP Cams Ultra Pro Magnum rocker arms feature a fully rebuildable design, which means that they very well may be the last rocker arms that you ever have to purchase”.
New Summit Racing price: $327.97.
Selling with free shipping: $265.00.
13) Crower Steel Billet SBC +.150” / AMC 390/401 Connecting Rods.
P/N LW93008B –
5.850” C to C / 2.225” BE bore (2.100” journal size) / .927” bushed SE bore.
7/16” through bolt. I-Beam steel billet 100% American metal, American made. H-11 rod bolts. Weight is approximately 620 grams.
Condition: New in box.
Quantity: 1 set of 8.
New from Crower $1650.40 with Cap Screw (p/n ML93008B), Crower has sale price of $1,499.99.
Selling with free shipping: $975.00.
14) Oliver Steel Billet SBC +.150” / AMC 390 / 401 Connecting Rods
P/N C5850STUL8
7/16” through bolt. Parabolic beam delivers the highest strength-to-weight ratio of any connecting rod made. 100% American metal, American made. Weight is approximately 590 grams.
Quantity: 8
“All Oliver Rods are precision machined using only mill-certified aircraft quality E4340 chrome moly alloy, heat treated to produce a 100% martensite grain structure. Made in America by the finest craftsmen in the world. Ultra Light Series rods are designed to be used in moderate horsepower applications where RPM in the 8,200 range are common. These rods are often used in 360 Sprint cars with spec heads or pavement late models. Lightweight pistons are recommended.
This rod features premium 7/16” bolts”.
Internet pricing: approximately $1300 - $1500.
Selling with free shipping: $1,100.
15) AMC factory forged 390 (1970 tall deck) / 401 Connecting rods. 5.858” C to C.
Condition: Used cores.
Selling with free shipping: $175.00.
NHRA SS/G
1970 AMC AMX - 390 4-speed
Jeff Lee
Re: .904" Chilled Iron lifters, Billet Rods, flat tappet, ro
Post by Jeff Lee »
#14 Oliver Rods are Cap Screw Rods (not through bolt).
NHRA SS/G
Jeff Lee
Post by Jeff Lee »
OFFERS?
NHRA SS/G
Jeff Lee
Post by Jeff Lee »
Item #4 - Schubeck lifters - SOLD -
Would really like to sell the connecting rods.
WTB - .904" Isky EZ Roller lifters.
Thanks for the ad space!
NHRA SS/G
Jeff Lee
Post by Jeff Lee »
#5 Isky Chilled Iron Lifters - SOLD -
$12 Comp Pro-Magnum Rockers - SOLD-
#14 Oliver Rods - SOLD-
Thank you.
NHRA SS/G
