For Sale: Used SERDI Micro 2000
harry813
Post by harry813 »
Gently used, comes with everything as pictured, includes 11 various straight pilots (not carbide) .3789, .3783, .775, .3761, .3755, .3429, .3121, .311, 2758, .2598, .196
Please make reasonable offer or trade, If you know what this is you know what its worth.
For more information/questions please Contact harry.whiteside@gmail.com
The SERDI Micro 2000 is an user friendly portable multi-angle seat cutting unit with precision dual plane centering system. Ideal for low volume motorcycle and automotive shops.
The MICRO 2000 bolts directly on any type head or uses the heavy duty UNICLAMP to speed the set-up time.
With 30 degrees body tilt and 8 degrees spindle tilt, the MICRO 2000 accommodates any canted and compound valve head configuration.
• User friendly ergonomic design.
• Easy tool setting, multi-angle seat machining and seat pocket counterboring.
• Uses standard SERDI tooling for machining accuracy and economical up-grade to bigger equipment.
• Bit holders mounted directly into the spindle to eliminate the need for tool holders.
• Machining capacity from 18 mm to 30 mm or from 14 mm to 30 mm with optional spindle.
• Precision sliding gauge for consistent cutting depth control, total travel with 0.02 mm increments.
• Rugged and heavy construction: 4.3 kg.
• Bolts on any kind of cylinder head or uses the heavy duty uniclamp system to speed the set up time.
• 30 degrees body tilt and 8 degrees spindle tilt accommodate canted and compound angle valves.
harry813
Re: For Sale: Used SERDI Micro 2000
Post by harry813 »
SOLD
