Dry Sump Pumps
Wulff Stage 5 $350
Weaver Brothers Stage 3 Pump, Pulley & Belt $225
518 Gear $25
522 Gear $25
511 Gear $25
5.28 Franklin Gear $25
C&R Gear Set 17 New $75
Bert Bell (Ear has a Chip) $125
Bert Starter New $145
Bert Coupler w/ Flywheel $75
Bert Flywheel $20
Remote Oil Filter $15
Halon Bottle with Cord $65
Halon Bottle $50
Mallory Tach $25
Autometer Tach $25
Autometer Tach (From Nascar Team) $100
Woodward Rack $400
Sweet Rack $225
Appleton Servo $50
Steering Rack $75
Firewall Grommet New $10
Carb Spacers
HVH 1 inch spacer $75
HVH 2 Inch Spacer $100
Base Plate $15
MSD Firewall Through New $10
Water Pump Chevy $30
Waterneck with Spacer (Swivel 16AN) $75
Roller Bearing Gas Pedal New $80
NEW shock Gauge $60
Power Master Alternator (Tested Good) $100
Ring & Pinions From Hendricks & RCR Teams (In Great Shape) $125 Each
3.10 Ring & Pinion
3.50 Ring & Pinion
3.60 Ring & Pinion
5.43 Ring & Pinion
4.71 Ring & Pinion
3.16 Ring & Pinion
3.50 Ring & Pinion
Switches & Hold Downs $30
Tube Grease $5 Each
Fuel Pumps
Ford Fuel Pump $50
Carter Fuel Pump for Parts $15
Carter Fuel Pump $50
2 Fuel pumps $5 Each
Braided Line
Braided Line 60 Inch 16AN 1 90 1Str (2) $35 for Both
#8 & #10 Hoses & Fittings $20
Full Flow Fittings #10-#8, #10-#6 $15
Fittings #3-1/8, 1/2 Pipe, 3/8-1/8 reducer $15
Quick Connect & Assortment of Fittings $20
#8 90-str, #6 90-45 Lines $25
16AN 6ft Braided Line & Fittings $35
Carbon Fiber line 70 1/2 & 75 1/2 16AN 45 & Straight $40 for Both
16AN to 12An Reducer $8
Radiator Hoses
2 1/2 Dayco Gold Stripe 22Inches Radiator $25
Dry Brake Pcs $5 Each
10 Ton Port-a-Power $75
Brake Pads
New Performance Brake Pads 7772.93.30.34 $30
New Performance Brake Pads 7735.80.20.34 $30
New Performance Brake pads 7770.83.28.34 $30
New Performance Brake pads 7735.80.22.34 $30
Wilwood Brake Adjuster New $65
Brake Adjuster (Can’t find name on it) $15
Stewart Brake Development $20
3 Brake Fan Coolers $10 Each
New Performance Friction Brake Rotors $45 Each
323.32.0046.37
313.32.0042.37
Tire Grover $50
MSD Box $75
MSD Hot Box $125
Radio Wiring $30
Seatbelts
Simpson July 2010 $30
New Racequip March 2014 $58
Schroth Seat belt Hardware Huge Stack $150
Spring Rubbers Big Springs $5 Each
Jack Screw Used $2 Each
Jack Screws New Have Different Sizes $4 Each
Adjuster Sleeves Used (6) $4 Each
Slugs $5 Each
Oil Cooler $40
Oberg Filter $30
Rear-end Pump $100
Aluminum Power steering Tank $50
Oil Pump Bracket $10
Sweet Powersteering Bracket $15
Regulator $40
Aluminium Brackets 1 ½ $15
Remote Master Cylinder Parts New $10
Blue Streak Plug Wires $30
Motorola Chargers (3) $20
Motorola Batteries (3) $20
Motorola P110 (7 Radios, 8 extra batteries, 3 individual chargers, 1 6 radio charger, 6 radio clips) $500 OBO
Used Upper Control Arms $5 Each
10 1/2
6 ¾
5 1/2
7 1/2
7 1/2
7 1/4
9
8
10
9 3/4
8
8 3/4 1 1/2 Positive Caster
9 1/4
7 Positive Caster 3/4
7 1/4 Positive Caster 3/4
7 Positive Caster 9/16
7 1/2 0
Window Nets
Window Net 23 x 16 Sept 2010 $10
Window Net 26 1/2 x 16 Dec 2012 $15
Oil Tank Heaters $10
Autometer Shift Light $35
MSD Shift Light 8700 Chip $45
Exedy Racing Clutch Like New $200
Push Rods
Push Rod 8.25 Assortment (22) $10
7742 Comp Cams 8.250 .080 (6) $5
7934 Comp Cams 8.550 .080 (4) $5
7121-8075 7/16 x .120 8.075 (4) $5
Assortment 8.700 $5
1/2 x .188 8.010 single taper (7) $5
8.850 .165 DBL Taper (6) $5
Kriner Race Engines 8.445 (4) $5
8.650 .165 (6) $5
CV 8.650 .080 (3) $5
CV 8.400 .080 (6) $5
CV 8.850 .080 Taper (5) $5
Assortment of Sizes $5
16 New Del West Retainers $30
RODS
6.125 Carillo Rods w/ bolts $150
6.00 Carrillo Rods w/ Bolts $150
6.125 Carrillo Rods w/ Bolts $150
6.200 Carrillo Rods $125
Valves
Del West Valves 2.15 Stem Size 6mm $30
Xceldyne Valves 2.15 Stem Size 6mm $30
Del West Valves 1.62 Stem Size 6mm $30
Wrist Pins
Wrist Pins Capricorn 20mm 7.87 Hardened $25
Roller Rockers $50
3 Trans Line Up Shaft & Pilot Bearings $5
Trans Mount Energy Suspension $10
Pit Gun From Nascar Team Parts Sell $150
Quarter Master Throwout Bearing $75
Pumps, Rods, Valves, Racks Hugh List For Sale
- New Member
Re: Pumps, Rods, Valves, Racks Hugh List For Sale
Hello,
I was reading your ad andwas interested n buying a few of the items you have listed for sale. Are the roller rockers for 7/16 studs? If so I will buy them. I assume the Carillo rods are large journal sbc and 6.0 inches long. If so I want a set of those too. I also want the 16AN braided line you have listed for 35 dollars for two pieces with fittings on them. Can you email me at martinezjohn327@gmail.cm and let me know how to proceed with the purchase? Do you take credit cards?
Thanks,
John Martinez
Albuquerque, NM
Thanks,
John Martinez
Albuquerque, NM
PM Sent
Custombalancing.com
We Make Honey Out of Dogshit*
* some conditions apply.
