New Quick Fuel / Proform "950" aluminum main body:
(http://www.jegs.com/i/Proform/778/67108 ... Id=1151139)
- 1.450" venturi w/stepped downleg boosters
- Includes baseline high-speed air bleeds & idle air bleeds
- 2nd generation main body design with air bleeds moved farther out of airflow path to improve metering response
* This main body will net close to 100 CFM (dry) increase over traditional Holley 80496 "950" HP w/ 1.375" venturi.
* For someone w/ a Holley 80513 "1000" HP w/ 1.562" venturi & downleg boosters, it will improve booster signal, throttle response and shift recovery significantly with a net airflow reduction of only ~ 50 CFM (dry).
* Can also be a nice upgrade for the standard Holley 850 DP, or any other carb using a 1.75" throttle body w/ 4-corner idle adjustment
New Quick Fuel / Proform 4-emulsion 2-circuit billet metering blocks (Proform has purple anodizing, QFT has red, but same part)
(http://www.jegs.com/i/Proform/778/67150 ... tId=752040)
- 4 emulsion holes vs. OEM Holley cast metering blocks w/ 2 or 3 non-adjustable emulsion holes
- ALL circuits are tunable: PVCR, IFR, emulsion
- Includes baseline PVCR, IFR, primary & secondary jets, and emulsion configuration compatible with the main body above
This is a package deal for the main body & the metering blocks. Check today's prices for everything here new and you'll see about $370 worth of parts from either Summit or Jeg's. My deal is everything for $325 shipped to the lower 48 states.
Cash, U.S.P.S. money orders and Cashier / Certified checks only. Sorry, no PayPal.
PM me here if interested. - Brad
QFT / Proform "950" Main Body + Billet Metering Blocks
Re: QFT / Proform "950" Main Body + Billet Metering Blocks
Price REDUCED from $325 to $300 shipped to the lower 48 states.
Parts no longer for sale; being re-allocated to a different project.
