sbc scat crankshaft 3.48 lightweight
Used scat crank for sbc , mains and rods are .010 under 3.48 stroke lightweight 45 lbs call or text 901-634-4502
- New Member
Re: sbc scat crankshaft 3.48 lightweight
Good Morning Sir,
Is the crank still available? Where are you located? How long was the crank used and was it involved in a misshap in an engine? What were the rotating weights- piston, rods etc. Has the crank been magnafluxed sense removal? Additioal information would be helpful.
Thank You,
Curtis
Thank You,
Curtis
piston weight was 470gr rods 505gr has not been checked since i bought it. rod and mains are .010 under. original owner says it has 40-50 nights on it. located in Memphis, TN
