I'm looking for an Edelbrock Victor head for BB Chrysler #77919 (bare) or #77929 (w/ valves) specifically with a Lot Date (on box label) BEFORE 10/2011.
That's the cut-off point when Edelbrock told me they switched from the original 75cc chamber to their later 72cc version. My heads are the earlier 75cc chamber version and I am looking only for a single replacement, although I might consider a "deal" on a pair.
Also, the MP Stage VII part# P5153654 should be the comparable head under the MP label, depending upon when Edelbrock cast them.
If you want to see the difference between the two Edelbrock versions, here are links to views of both chamber sizes:
75 cc: - http://www.hughesengines.com/Tools/Popu ... ug4656.jpg
72 cc: - http://board.moparts.org/ubbthreads/upl ... ics005.JPG
If you have one, send Private Message to me here with any details you can provide. I'm located in Northern Virginia, outside of Washington, D.C.
Thanks,
Brad
WTB - Edelbrock 77919/77929 Victor head for BB Chrysler
Re: WTB - Edelbrock 77919/77929 Victor head for BB Chrysler
9.10.2013 - Consider this ad "DELETED", although I'm not seeing either an Edit or Delete option for me to use to remove it...
Back from the dead... I've ended up with a single 75cc (early) 77929 head and am curious if I can find a match for it.
Head I was looking to find match for has been sold. No longer need a single. Thanks.
