Local guy dumped this on me to check out and has little interest. As far as I know was about a 1100hp deal.
Specs.
4.600 bore Donovan aluminum block (Solid no water jacket) billet mains
4.25 stroke Callies crank
JE piston (15.0:1)
Oliver rod
Stefs pan
Jesel belt
Comp Custom cam
Comp lifters
T&D rockers
Taper pushrods
Profiler heads
Profiler single carb Ram style intake
ATI damper
Sheet metal valve covers
Engine components have been magged and are crack free. Engine has about 350 1/4 mile passes in a dragster (7.30's@ 3000ft) since new.
To anyone interested I will freshen, (rings bearings belt and seals rod bolts valve springs lifters oil pump gaskets) hone cylinders valve job dyno and ship to your door for $14,500.
For no additional cost if you send me your carb ignition and vac pump I will set up and dyno complete, or for additional cost set up with a new carb crank trigger and distributor and vac pump of your choice.
This is a feeler to gauge interest or if I let it sit for a while. Feel free to call me at 208-853-RACE or email me @ psiracingengines@gmail.com
Thanks for looking.
565 Donovan/Profiler Freshen to suit, feeler ad.
