I have available an older Kwikway Valve refacing machine. I replaced all of the bearings in the unit, replaced the belt and converted the machine over to an Ericsson collet chuck. I have collets for 5mm, 7mm and 8mm valve stems, and you can readily get other collets from MSC Industrial. Collet are double-taper type and machine holds .0002-3 without any problem. Price is $450
Also available is a Kwikway Seat Grinding set. Price $350
Call Paul @ 919 757 6888 or email to pheyden@ieee.org
