383 SBC Short Block
5140 LA Crankshaft STD/STD 3.750 Stroke
Milodon Windage Tray
6" Eagle H Beam Rods
ICON Premium Forged Pistons (Part # IC733) .005 in the hole with .041 head gasket calculated to 12.9 to 13 to 1 used a fel-pro 1003
Comp Cams Roller "Custom Grind" (Specs to serious buyer)
Comp Cams "Horizontal Bar" Roller Lifters
HellFire Rings
Clevite Main and Rod Bearings
Melling Oil Pump W/Milodon Pick Up
Summit 9 Qt. Drag Race Pan
ARP Studded Mains and Heads
010 High Nickel 350 block clearanced and vent tubes tapped and installed in lifter valley.
Motor has 12 passes on it since being freshened up...
Motor with AFR 227's Super Victor and Pro Systems 950+ Carb and 1 3/4" headers in 3100 lbs. went 10.29 @ 129.6 MPH - Motor made safely to say 630-650 HP at the crank...
$4200.00 OBO
If interested call Bill @ 916-844-6913
