-Valve Spring checker #913-81103. Excellent Condition. $35.
-Longacre Deluxe Tire Pyrometer #50690 - excellent condition with very little use. Great for tracking camber changes and tire use. Memory for multiple reads, instruction manual, carrying case. $275.
-Spring Rater - Like New - $200.
-SBC Pushrod checker, 3/8's and 7/16 - $10 for pair.
-Intercomp Electronic load cell for spring checker - make your own! Powers up, 9V. $100.
-Used 14" Diameter x 3" K&N - (2) Available, $10 each. 4" tall Kool Blue $10.
-Misc. SBC head gaskets (Nothing special, from re-man kits). $8 per set.
-HP 750 gas Carb, List #80528_2, used about one season, in like new condition - $425
-Diesel Compression Tester. $25.
-Comp Roller Tip Rockers, brand new in unopened box, part #1412-16, 1.52 ratio, 3/8's stud, for SBC, $100 each set (2 Sets available).
-Large Caliper Floater Brackets - Left and Right - New - $20 for Pair.
-UB Metric Brake Floater Bracket - $10.
-Modified Headers - $50 for Pair.
-Birdcages and Clamps - $100 for all 7 Pieces.
-Large Caliper Brackets - $5 for pair.
-SBC Exhaust Manifold Set - $10.
-Stock SBC cast iron 4 barrel intake manifold, spread bore pattern. $10.
-SBC 3973493 Cylinder heads, Pair, press in studs, complete with valves, springs, rockers, 1.94/1.50 valves, steam holes, For 71-72 400, 76cc chamber. $15 pair.
-SBC 3998993 Cylinder heads, pair, press in studs, complete with valves, springs, rockers. $15 pair.
-C6 Ford automatic, from full size early 80's Ford van, fits 300/302/351w - $50.
-B&M #80250 automatic trans pan drain plug kit - $3.
-Spectra Preminum #CU1451 factory replacement radiator. Ordered to fit a 1996 Ford F150, 5.8L, with A/C or HD cooling. Aluminum core, plastic tanks, brand new in box - $100.
-Troyke 12" Cross Slide Turn Table in good working condition - $300.
-168 tooth flywheel - $20.
-168 tooth flex plates - $10 each.
-168 tooth 400 flex plate - $10.
-168 tooth 400 flex plate with sfi tage - $20.
-Stock GM starters - one straight pattern, one offset pattern. $10 each.
-Ford SROD aluminum 4 speed, from 83 Mustang 5.0GT - $100.
-Balljoint Holders - $2 for the pair.
-Kirkey #00600 seat addon - $5.
-New Old Stock 1 Gallon Vented Fuel Can (No Longer Made!) $15 each
-New Old Stock 5 Gallon Vented Fuel Can (No Longer Made!) $25 each
-John Deere 316. 1985, has P218G Onan engine, no hour meter, 48" deck, hydraulic lift, hydrostat trans, runs and mows well, smokes when warm (not enough to foul plugs) - $750.
-383 SBC, stock cast crank, 5.7 stock rods w/aftermarket bolts, hyper flat top pistons, flat tappet cam, Dart Platinum 200 steel heads, Comp roller tip rockers, Victor Jr 4 barrel intake, Kevko circle track oil pan. External balance engine, 4 bolt main 2 piece rear main seal block. Engine has 26 nights on it, has always been rev limited to 6800rpm max, about 11:1. Complete from damper to balance plate and from oil pan to intake manifold. $2000.
PM or call 269-588-0041. Located in Bridgman, MI, 49016. Will ship at buyers expense (except big items).
Tools - Odds and Ends - Engine - All For Sale! W/ Pictures
Re: Tools - Odds and Ends - Engine - All For Sale! W/ Pictures
These items have been sold.
For all future reference, anything that has a red x for a picture has been sold. Thank you.
