BRAND NEW,not rebuilt,mini starter,3 h.p.,168 tooth,$185
8-JE NEW LOW TENSION 4.030X3/16 OIL RINGS ONLY- $25
Manley standard length super duty sbc valves,8-2.055,8-1.60 ground and ready to install. $130
GM 1.6 STAINLESS pro flow ex valves NEW $75
Jegs 1.6 ratio,7/16 full set roller rockers $85
Manley #22441 1.550 valve springs,brand new,$110
Moroso oil pan,#20211 used $75 each
MELLING M55HV billet gears oil pump NEW $40
Moroso oil pump pick up #24360 New $39
Powerglide trans shield $25
Several powerglide cores,make offer
Phoenix slicks 9x30x15 $50
NEW Comp Stamped Steel 1.5 Ratio 3/8 Stud part#1212-16 $45
1.76 Hardened powerglide input shaft TURBO splines $60 USED
1.82 Hardened powerglide input shaft $60 USED
Moroso powerglide pan #42000 $65
NEW Scat 168 tooth internal bal flex plate $50
RJS 5 point Belts outdated $25
AFCO 90/10 shocks 67-69 Camaro $45 used
Prices do not include shipping
Contact Steve at et7333@netzero.net
SBC PARTS
