Parts for Sale
Koolaid
Parts for Sale
Post by Koolaid » Tue Dec 21, 2010 8:18 am
(1) Lunati Cam, #50154, SBC, used, Solid Roller, 3800-7600 power band, 256/264 @.050 duration, .648/.627 w/1.5 rockers. $125.
(1) Comp Roller Lifters, brand new in box, part #818-16 for SBC. $300.
(3 sets) Comp Roller Tip Rockers, brand new in unopened box, part #1412-16, 1.52 ratio, 3/8's stud, for SBC, $100 each set.
Quick Fuel 4412 E85 2 barrel carb, race your high compression 2 barrel engine on cheap fuel! Was only used for a few races, I purchased and sold the car it was going to go on. Comes with an adjustable regulator and a Stewart Performance RPS1500 piston style lightweight fuel pump. Carb alone retails for $460, you get carb, regulator, and high performance pump for $425.
Alemite aluminum crossfloat alignment turn tables. Lots lighter than steel turn plates, in good condition. $125 for the pair.
Break-in roller rockers for SBC, 1.3:1 ratio, 3/8's studs, full set, Speedway brand, excellent condition, use these instead of breaking in with smaller valve springs. $125 for the set.
Longacre Deluxe Tire Pyrometer - excellent condition with very little use. Great for tracking camber changes and tire use. Memory for multiple reads, instruction manual, carrying case. $275.
4 Gallons of assorted tire soak. $12 per gallon.
Holley HP750 carb in excellent condition. Not a thing wrong with it - just don't use. $425.
All items located in Bridgman, MI, 49106. Shipping available at buyers expense (no shipping on tire soak). Email, PM, or call 269-588-0041. Delivery to Kalamazoo, MI area a possibility on weekends.
Koolaid
Re: Parts for Sale
Post by Koolaid » Wed Jan 05, 2011 7:37 am
Here is what I have left:
(2 sets) Comp Roller Tip Rockers, brand new in unopened box, part #1412-16, 1.52 ratio, 3/8's stud, for SBC, $100 each set.
(2) Speedway / Deco coil spring raters. They can be used to rate 5 or 5.5" coil springs with flat ends of pigtail ends. Both are hydraulic. The first one is in excellent condition, very little use, the head was sent in and rebuilt and has not been used since. $200. The second one is in working condition, but has more use on it - the gauge has been replaced at one point and the hydraulic jack tends to leak a little bit. $125 for this one.
Bunch of odds and ends that can be seen at: http://picasaweb.google.com/jkollath/ForSale#
Koolaid
Re: Parts for Sale
Post by Koolaid » Fri Mar 11, 2011 7:07 am
This ad is no longer valid - everything is sold. Thank you.
