I have searched for over 20 years for a substance that will seal a cylinder head forever. I recently had to extensively weld on a set of heads and there was no way I was going to seal this thing up entirely due to the contamination in the water jacket. You always have pin holes or god forbid a crack that you just chase and never seal up. These heads had a nasty crack a half inch long that just rained water out of it. I found a gas tank sealer called KREEM that will seal just about any crack or pin hole leak for GOOD. You just clean the head, pour it in and coat the entire water jacket, let it dry and do it twice more. The really cool thing about this stuff is that it does not change the thermal properties of the cylinder heads. If it does its so imperceptible as to be not worth talking about. It comes in a kit complete with metal prep for those rusty old cast iron heads. It does not react to alcohol, race fuel or other solvents. Its also remains pliable and expands and contracts with the heads. It also adheres to the water jacket even if it has residual rust like nothing I have ever seen. If you have a leaky head that you just cant fix, You can fix it with this stuff. You can inquire where to find it here.
KREEM Products
PO box 399 Somis California
805-386-4470
