launch rpm
- New Member
launch rpm
What would be a good launch rpm for a 2200lb car. 4500 stall converter 5.14 gears transbrake. Cam works from 4500 to 7200. DAN
I am against revving one up and loading it on the convertor. My suggestion is to try several different rpms and start with maybe 3,00 rpm and flash the convertor by stomping the pedal as you are ready to launch and release the brake. Your rpm at launch should improve by flashing the convertor like this. Adjust your rpm uo and down slightly to see what works best.
Ed
Ed
- New Member
Why is it a bad idea to go flat against the converter? I am not arguing with you, just asking.I only ask because that is what I do and I come here to learn from those more experienced.Ed-vancedEngines wrote:I am against revving one up and loading it on the convertor. My suggestion is to try several different rpms and start with maybe 3,00 rpm and flash the convertor by stomping the pedal as you are ready to launch and release the brake. Your rpm at launch should improve by flashing the convertor like this. Adjust your rpm uo and down slightly to see what works best.
Ed
Not a bad idea, you won't hurt anything unless you sit on it too long and fry the converter. Most cars will have a better 60 ft time if you rev limit below the stall speed and let the converter "flash" up to the stall speed. You can also adjust your reaction time by raising or lowering the launch rpm.
You need to loosen up the convertor some more. wheelsup is correct in how to maximize the launch.us7race wrote:My Truck picks up if I go against the converter. The 60' picked up from 1.36 to 1.33 picked up .07 too in teh 1/8th..
Blessings.......Ron.
Creekside Racing Ministry
John 14:6
Ron Clevenger
CSU Gas Dominator ProCharger nonintercooled
Top Eliminator West http://www.topeliminatorwest.net
Steve Morris http://www.stevemorrisengines.com
6.49@219mph (still tunning)
John 14:6
Ron Clevenger
- New Member
