ideas needed in launching an old c4 vet
Any type of racing
olddragguy
Postby olddragguy » Tue May 18, 2010 1:24 pm
i have a manual trans c4 vet, but no matter what i do i seem to be stuck in the 2.0 60 ft range with my best being a 1.86 after 50 runs . i have treid all sorts of rpm ranges. i even bought the new nittos thinking it might be the tires but to no avail . can anyone give me some ideas to explore . ps the car has 400 rwhp. and has run a best of 12.23 @116.80 with a 2.02 60ft on that run .
Y BE AVG
Re: ideas needed in launching an old c4 vet
Postby Y BE AVG » Wed May 19, 2010 8:29 am
How is the car leaving. spinning, dead hook? what rpm seems to work best? If it's hooking and you have stock gearing.... I'd change that first.
Corey Clayton
Clayton Racing Engines 630.532.4052
Stocking WD for DART/AFR/Trickflow/Callies/Compstar/SCAT/CP-Carrillo/Mahle/PAC springs
olddragguy
Postby olddragguy » Thu May 20, 2010 1:50 am
this car has 3.92s .if i try to leave at higher than 2400 the car spins up to a 2.18 and runs 12.70 @115.66 . this was done last fri at famoso bets run was 12.307@117.23 mph 60ftwas 2.029 330 ft5.372 1/8 8.076@92.80 1000 ft 10.375 worst run 12.741@115.66 mph 60 ft 2.18,5.641,1/8 8.442@89.52,10.783. runs done on the new nitto nto1 . 315x35x17 pressure 25lbs. the car is a 91 zr1 corvette, fidanza flywheel jeal headers 3 in exhaust with 3 in super turbo mufflers. car also has coil overs with the fx3 system still working
Y BE AVG
Postby Y BE AVG » Thu May 20, 2010 8:35 am
havent run the new nittos yet but the old ones worked best for us at 18-20 psi whenever we tried them.
Corey Clayton
olddragguy
Postby olddragguy » Fri May 21, 2010 3:32 am
after talking with the tech dept of nitto. they say that the nto1 will hook better running 26-28 lbs of pressure cold .its the way theydesigned the tire . when i had my mickey t drag radials i used to run 16-19. i am thinking i may need to go to a 16 in tire so i can get a larger sidewall. which might help the car hook . either that or bite the bullet and put a auto trans in her .
Boris
Postby Boris » Sat Feb 26, 2011 3:09 am
Any one who has run new nittos . What you have feel the difference on the performance basis as compared with old one . I would be thankful if someone would share ideas here .
sh0wtime37
Postby sh0wtime37 » Wed Jun 15, 2011 11:56 am
Reviving an olde.
I would definately try the lower pressure. MT drag radials act that way. Assuming you weigh in at aound 3500 your only looking for another tenth or so i would drop the pressure. Are you chasing a certain ET?
were those numbers better with the MTs or identical? in other words, for you , which work better???
your dealing with 17" rims too. not gunna do much else for you I would think. go buy some 15's or 16's and some more side wall (if they fit).
Your next best bet, is to get a some sort of lauch controller, take out some timing to get the wheel speed. Are the coil overs on the front or back? loosen up the front some more possibly. Add/move some weight... take your nocks low, accelerate faster on the top end.
flyingwedge
Postby flyingwedge » Mon Nov 12, 2012 12:10 pm
olddragguy wrote:i have a manual trans c4 vet, but no matter what i do i seem to be stuck in the 2.0 60 ft range with my best being a 1.86 after 50 runs . i have treid all sorts of rpm ranges. i even bought the new nittos thinking it might be the tires but to no avail . can anyone give me some ideas to explore . ps the car has 400 rwhp. and has run a best of 12.23 @116.80 with a 2.02 60ft on that run .
>>I would get skilled pictures of your car at launch, side and rear. I suspect it's "squating", and this will cause the tires to "decamber", reducing the footprint. "Maybe" something like a urethane, tall pyramid bump stops, to limit compression travel. If this is doable, then get the rear camber to zero, at this load height. I like the taller sidewall suggestion, as for more forgiving of camber change and might like the bump stops for benefical tire shock,(larger footprint). Good Luck, flyingwedge. :)
23Root
Postby 23Root » Sat Dec 15, 2012 10:17 pm
that is not a very forgiving tire at those pressures, i would agree that you are loosing most of your surface area on launch.
I would stiffen the rear if possible or like mentioned before go with longer bump stops to keep the car from "squating" as much.
we have ran many older vettes but we used much bigger tires :)
Return to “Driving”
Who is online
Users browsing this forum: No registered users and 1 guest
