8" Torque Converter actual size
Transmission to Rear-end
dniccoli
Post by dniccoli » Sun Nov 25, 2018 11:37 am
Hey guy's, just received a brand new 8" converter from PTC to replace an old 10". I was expecting to open the box and find a smaller converter but this new 8" is exactly 10" across! It has PTC 8 stamped on it but dimensions are the same as my 10" and probably weighs the same, does that sound right or am I missing something? I tried emailing PTC with the size question but have not received a response as of yet, plan to call as soon as I can. Thanks for any insight you all can share.
Coloradoracer
Re: 8" Torque Converter actual size
Post by Coloradoracer » Sun Dec 02, 2018 9:41 am
Converter size isn't determined by the outside but by the turbine size. Not uncommon to see a converter listed as one size but measures another...it's inside that counts, and if it was properly configured to your combo.
Mark Goulette
Authorized Amsoil Retailer
BOOT
Post by BOOT » Fri Dec 07, 2018 2:05 pm
Even if it weight the same or more, it's possible the weight is now more central and it has less inertia. Also is there a balloon plate in either?
