rear end axles
Transmission to Rear-end
DJ5
rear end axles
Post by DJ5 » Mon Feb 12, 2007 10:32 pm
what is a floating axles work. an how does it work.
thanks
Masher Manufacturing
Post by Masher Manufacturing » Tue Feb 13, 2007 12:26 am
The best way to describe it is to look at a 1 ton and larger truck.
On a full floating rear, the only thing the axle shaft does is make the wheel turn. The wheel is held on with a set of bearings like a front wheel. If the axle breaks, the wheel stays attached but won't be powered.
A semi floating axle is found on 1/2 trucks, some light duty 3/4 ton and many cars. With this application, the axle makes the wheel turn and holds the wheel on. If the axle breaks not only will the wheel stop receiving power, it may fall off depending on the type of outer bearing.
