Turbo 400 shift problem
Transmission to Rear-end
econo racer
Post by econo racer » Mon Sep 03, 2018 6:27 am
I have a good turbo 400 stock.Works perfect but shift it in low and run wide open and it shifts buy itself approx 4500 rpm. I need it to go to at least 5500 rpm. I also do not want a manual or reverse shift. Want it to work stock. Any suggestions? :?
In-Tech
Re: Turbo 400 shift problem
Post by In-Tech » Mon Sep 03, 2018 9:30 pm
Lighten the governor weights. Somebody used to make a kit, B/M comes to mind. It's been a long time since I messed with this stuff, I sort of remember an adjustable modulator would change not only part throttle but full throttle a little too. Hopefully one of the trans pros here will chime in.
-Carl
6.50camaro
Post by 6.50camaro » Tue Sep 04, 2018 6:45 pm
No Pro , but have played with the B&M kit a little . The govenour contols shift point even if the lever is left in Low.The trans can be modified with some shift kits to hold in gear no matter what rpm's are. If you go the route of springs and weights start mid way on weights and springs and check. Lighter weight or softer spring raises shift point. The Lightest weights and springs will put you past 6500 rpm's before shift. If you have a line lock you can check shift points doing a burnout. Good Luck . Dan
TRN
Post by TRN » Thu Sep 13, 2018 1:50 pm
Do you have a WOT switch connected?
GLHS60
Post by GLHS60 » Sun Sep 30, 2018 4:06 am
This isn't really a problem as stock TH-400's had this feature.
Higher H.P.Engines have a higher "Governor shift" RPM than lower H.P.Engines.
As mentioned, the "Governor Shift" point RPM can be tuned to suit your needs.
I grind some metal off the governor weights to lighten them up to increase the 1-2 shift point.
I like the firm shift to 2nd, with the shifter in low feature, and find it very consistent!!
Thanks
Sherwood Park
Alberta,Canada
vds
Post by vds » Tue Oct 16, 2018 12:18 am
You will need to modify the 1-2 shift valve to stop it upshifting in to 2nd, with manual 1st selected
Hydramatic designed it this way I wouldn't suggest attacking the govener
geraldtson
Post by geraldtson » Tue Oct 16, 2018 10:01 pm
I agree. Go to crankshaft coalition turbo 400 rebuild tech,scroll about halfway down page till you see valve body.
"You must remove 1-2 shift valve and grind to flats on the land designated by arrow and plug exhaust hole in the valve body also designated by arrow".
That's all.
