crowerglide vs. bolt together converter
Transmission to Rear-end
Brent Foster
Post by Brent Foster » Fri Feb 02, 2007 7:49 pm
I was wondering if any of you could give any experience/oppinions on this subject. I'm running a powerglide with a standard high stall coverter. Racing in 200ft dirt drags with DOT tires. Will a bolt together converter give me alot of flexibility that could get me in a good area or would the SCS and crowerglide application be the only way to get a "fine tune" on the power control to the ground?
Transman
Post by Transman » Wed Feb 21, 2007 10:35 pm
Bolt together will let you change a few things. But you have to pull the trans to get at it. You can change stators around which will have major influences on torque multiplication and stall speed to a point.
Dealer for TCI, JW, BTE, Trans Specialties, Jesel, Impact, etc.
