E4OD ?
Transmission to Rear-end
exhaustgases
E4OD ?
Post by exhaustgases » Fri Jun 08, 2018 4:10 am
In a 96 F250, does anyone know if it is DC or PWM shift solenoids?
exhaustgases
Re: E4OD ?
Post by exhaustgases » Sat Jun 09, 2018 7:30 pm
Maybe using the wrong terminology the DC since pwm is pulsing dc. I saw a parts listing that was no pwm.
midnightbluS10
Re: E4OD ?
Post by midnightbluS10 » Mon Jun 11, 2018 6:21 pm
I only saw non-pwm solenoids available for the E40D of that year. I believe the 4R100? uses pwm solenoids. I don't know much about Ford transmissions, though I do know some things swap between the 2. All the literature I saw showed non-pwm solenoids in a 96 E40D. No actual experience with them, so I'm not sure how much help that is.
https://www.summitvalvetrain.com/catalo ... 64494.html
5.3L valve interchange list
Pro Built Automatics
Re: E4OD ?
Post by Pro Built Automatics » Mon Jun 11, 2018 9:36 pm
PWM started in 1998 for the 4R100.
exhaustgases
Re: E4OD ?
Post by exhaustgases » Tue Jun 12, 2018 6:31 pm
Reason I asked is because there was a posting about a guy using a switch to operate the TCC clutch manually and to also make it a difficult thing for someone to steal the truck, since constant lockup would pretty much kill it when put in gear. I just figured 12 volts applied to a pwm solenoid would not end good. Thanks for the reply's.
