Turbo 350 question
Transmission to Rear-end
Geoff2
Turbo 350 question
Post by Geoff2 » Thu Apr 12, 2018 5:34 am
I am rebuilding a T350, 1977 model year.
These parts were missing upon disassembly: couple of the servo/accumulator springs, governor filter screen, only two 1/4" balls in the VB. So the trans has been apart before.
Low/rev, for & dir clutches, bushes, etc looked in good nick, all the frictions still had the waffle pattern, so little to no wear.
The int clutch had one severely warped steel,[ not referring to the waved plate ], other steels looked ok. Frictions still had the waffle pattern. Endplay was about 0.050".
All the rubber seals were still soft & in the correct positions, the five sealing rings on the stator shaft were intact, metal type with interlocking ends.
Any idea why this one plate warped?
SupStk
Re: Turbo 350 question
Post by SupStk » Thu Apr 12, 2018 12:52 pm
Maybe a used plate that found its way in during assembly?
The missing parts sounds like it had a shift kit installed.
Monty Frerichs
B&M Machine
