Turbo 350 K/down cable
Transmission to Rear-end
Geoff2
Post by Geoff2 » Sun Apr 01, 2018 5:22 am
Can this cable be disconnected without harming the trans? Thanks.
SupStk
Re: Turbo 350 K/down cable
Post by SupStk » Sun Apr 01, 2018 6:18 pm
Yes. The vacuum modulator controls TV pressure.
Monty Frerichs
B&M Machine
TRN
Post by TRN » Mon Apr 02, 2018 1:06 pm
You can disconnect the cable without harming the trans. The kickdown cable's only function is to set WOT shift points. If you want the trans to shift correctly at WOT then you need the cable.
