Pulling out in 2nd gear = PG
Transmission to Rear-end
oldhead
Post by oldhead » Sun Jan 21, 2018 4:39 pm
When I run pulling out in 2nd gear with my T400 simlar to a PG other then a small lost due to the trans. power loss :D :D :D :D Oldhead
Quicker then most
roc
Re: Pulling out in 2nd gear = PG
Post by roc » Sun Jan 21, 2018 5:20 pm
The gear ratios are quite different. 2nd gear on Turbo 400 is 1.48:1, top gear on Powerglide is 1:1.
Circlotron
Post by Circlotron » Sun Jan 21, 2018 5:34 pm
He is comparing second gear on a TH400 to first gear on a Powerglide.
roc
Post by roc » Sun Jan 21, 2018 6:08 pm
You're spot on, thanks.
oldhead
Post by oldhead » Sun Jan 21, 2018 9:49 pm
Thank you, I thought it was obvious....Oldhead
Quicker then most
oldhead
Post by oldhead » Sun Jan 21, 2018 9:51 pm
Does "Spot on" Does that mean yes or no. Oldhead
Quicker then most
Post by pdq67 » Mon Jan 22, 2018 6:40 am
"Spot-on", means yes!
Brian P
Post by Brian P » Mon Jan 22, 2018 7:16 pm
IIRC 1st gear on a powerglide is 1.82:1 reduction.
BOOT
Post by BOOT » Tue Jan 23, 2018 4:32 pm
As mentioned PG is 1.82 1st, 1.0 2nd
th400 is 1.48 2nd, 1.0 3rd
ZIGGY
Post by ZIGGY » Wed Jan 24, 2018 4:53 pm
Trivial comment - some PG's are 1.76.
RCJ
Post by RCJ » Thu Jan 25, 2018 6:02 am
1.82 X 3.73 = 6.78 1.48 X 3.73 =5.52 .
oldhead
Post by oldhead » Thu Jan 25, 2018 10:45 am
10 replys, 1 good answer, You guys are smarter then that :) :) :) :) Oldhead
Quicker then most
fdicrasto
Post by fdicrasto » Thu Jan 25, 2018 11:09 am
Are you "pulling out" of your driveway, or stop light or the line at drag strip? Low gear ratio in a glide can run anywhere from 1.60 to 1 to 2.05 to 1 and anything in between aftermarket. 1.76 is factory v8 low gear; 1.82 is factory 6 cyl ratio; Jeep glides had 1.95 or so in stock form. Not sure why you need to start in 2nd unless tire spin under race conditions was uncontrollable.
ZIGGY
Post by ZIGGY » Thu Jan 25, 2018 12:47 pm
Oldhead - sorry I'm an old head myself with too many dead brain cells
to understand what question is in your post. It appears you are happy that
you feel little difference between a PG and your T400 when starting in
2nd ??
fdicrasto - seen PG's in postal Jeeps but didn't know about ratio difference.
Thanks for that bit of info.
