posi fluid
Transmission to Rear-end
dondon
posi fluid
Post by dondon » Thu Jan 11, 2018 10:46 pm
Is that 4 ounce bottle posi additive needed on a 8 3/4 mopar cone type posi or is it only needed for the clutch type posi?
Geoff2
Re: posi fluid
Post by Geoff2 » Fri Jan 12, 2018 3:15 am
I have a GM axle that uses the cone style posi & it requires LSD additive. Don't see why Mopar would be different...
SupStk
Re: posi fluid
Post by SupStk » Fri Jan 12, 2018 9:53 am
On a related topic, is the aditive required when using synthetic lube with a clutch type limited slip? Or is the synthetic a bad idea? The differential is a 9" Ford with Trac-loc.
Monty Frerichs
B&M Machine
tresi
Re: posi fluid
Post by tresi » Fri Jan 12, 2018 4:39 pm
I've heard not to use synthetic with a limited slip rear end but that might only be worth what you paid for it.
Geoff2
Re: posi fluid
Post by Geoff2 » Sat Jan 13, 2018 4:46 am
I always buy rear axle oil that has the LSD additive as part of the oil. That way you know the two are compatible. I see no sense in buying 'straight' oil & adding 'something' to it when all the major companies make oils with the required LSD additive.
One of my diffs was noisy when coasting [ worn gears, no new replacements available ] . Tried two different brand oils to try & reduce the noise, no difference. Then I tried Redline 85/140 syn oil. Noise was almost eliminated, & I ONLY use Redline syn oil now in the axle.
stealth
Re: posi fluid
Post by stealth » Mon Jan 15, 2018 2:04 pm
Agree...
Good to hear the redline worked well. Have to give it a try.
BOOT
Re: posi fluid
Post by BOOT » Tue Jan 23, 2018 4:35 pm
I also prefer the stuff with additive in already that way no matter the rearend you have the correct ratio.
Re: posi fluid
Post by pdq67 » Sat Feb 17, 2018 8:21 am
I thought that GM's, "Posi-Trac", oil is used with Eaton clutch plate type rear ends?
So cones use it too?
Truckedup
Re: posi fluid
Post by Truckedup » Sat Feb 17, 2018 10:43 am
My experience with cone clutch are in the 8.25 Mopar rear used in Jeeps and a GM 8.5 truck rear that appeared to be an after market posi...They are metal on metal if that makes a difference,,,
