Bolt on yoke C4 ????
Transmission to Rear-end
Casper393W
Post by Casper393W » Fri Dec 22, 2017 6:24 pm
I have a Bolt-on yoke in my C4 for my F100. With 600hp I am afraid that the 1310 yoke is going to be a weak link. My question is does anyone know of a aftermarket replacement??? I would like to upgrade to 1350 joints at the same time
Thanks
Andy
SupStk
Re: Bolt on yoke C4 ????
Post by SupStk » Fri Dec 22, 2017 10:52 pm
Bolt on, are you talking a bolt going into the tranny output shaft or bolt on Ujoint straps?
Monty Frerichs
B&M Machine
Baprace
Post by Baprace » Sat Dec 23, 2017 1:26 am
I have used the outside clip smaller GM ujoints on circle track cars and the strongest ones are Borg Warner without the grease fitting. Second thing you might try Mark Williams.
Casper393W
Post by Casper393W » Sat Dec 23, 2017 10:23 am
Yes this trans has a fixed yoke that is bolted on to the output shaft.
SupStk
Post by SupStk » Sat Dec 23, 2017 12:56 pm
I don't recall seeing any having 1350 joints. Wonder if a 1350, 28 spline yoke can be modified to work?
Monty Frerichs
B&M Machine
SupStk
Post by SupStk » Sat Dec 23, 2017 1:10 pm
Just had a thought, not sure if E250 or E350s ever came with C-4s but their drivelines came with 1350 joints.
Monty Frerichs
B&M Machine
Casper393W
Post by Casper393W » Sat Dec 23, 2017 1:51 pm
That is a good thought...I would about bet it they would have a C6 never know I might could get lucky!
My next question: do you guys think...Spicer solid 1310 joints would hold up to 600hp in a 3800 lb F100 just footbraking?
SupStk
Post by SupStk » Sat Dec 23, 2017 4:52 pm
According to Spicer the 1310 joint will run at 400 ft lbs continuously and 800 ft lbs intermittently. Minimum elastic limit is 1600 ft lbs. Maximum rated RPM is 6000.
To answer your question, probably not and be happy about it. Might hang on for a while.
Monty Frerichs
B&M Machine
Casper393W
Post by Casper393W » Sun Dec 24, 2017 11:24 pm
Thanks for the info....I guess I will try my luck since I am running the solid joints... I just need to make sure it doesn't wheel hop....or chatter the drag radials...
I will keep everyone posted.
BigBlocksOnTop2
Post by BigBlocksOnTop2 » Thu Dec 28, 2017 12:13 pm
Mark Williams may have one. I have an Astro Performance A5 with a Williams 1350 yoke....250.00.
