Diff cap studs
Transmission to Rear-end
BOOT
Diff cap studs
Post by BOOT » Thu Jan 05, 2017 11:41 am
Stud or bolt upgrade worth it? ie gm 7.5, dana 44 or ford 8.8
psychomotors
Re: Diff cap studs
Post by psychomotors » Sat Jan 07, 2017 3:14 pm
Just use a cover with the preload set screws. Looks spiffy too. :D
Jagdpanzer
Re: Diff cap studs
Post by Jagdpanzer » Tue Jan 24, 2017 9:02 pm
Converted my C4 Corvette Dana 44 HD bolts to ARP studs:
cgarb
Re: Diff cap studs
Post by cgarb » Wed Jan 25, 2017 2:14 pm
In my experience with broken rear ends, the cap itself breaks before the fastener. My vote is for the preloaded cover. It's what I use on my 8.8 Ford. I thought of trying to fabricate something similar to that through the back of a 9 inch Ford housing and housing brace. Broke a nodular center section once, the caps busted in half. Ended up buying a Moser unit and those caps are way beefier.
