700r4 case ports
Transmission to Rear-end
BOOT
700r4 case ports
Post by BOOT » Sun Dec 25, 2016 8:46 am
Does anyone have a diagram or can list the case pressure ports of a 700r4
Fireonthemountain
Re: 700r4 case ports
Post by Fireonthemountain » Tue Dec 27, 2016 9:34 pm
You mean like this??
http://www.hotrodders.com/forum/700r4-f ... 02755.html
http://www.tciauto.com/tc/trans-line-pressure/
The pressures will vary with who did it and how, and what parts they use.
BOOT
Post by BOOT » Wed Dec 28, 2016 8:05 am
I mean like what port will test a certain gear, for example because of a vid I know what one is for 4th on the 700r4 and found a pic where they listed all the ports for a th350, no luck finding a pic or diagram of a 700r4
Fireonthemountain
Post by Fireonthemountain » Wed Dec 28, 2016 12:09 pm
Only one test port I know of on the 200R4 and the 700R, and that is the drivers side in front of the linkage and up a little, just as the links I posted said. All gears are tested for correct pressures from there.
BOOT
Post by BOOT » Wed Dec 28, 2016 3:08 pm
Thx but not what I meant, on the pass side there are a few ports, one had pressure in 4th and others idk
Greenlight
Post by Greenlight » Wed Dec 28, 2016 9:16 pm
Is this what you are looking for?
Project Greenlight
